how to use computer script/command to realize the adjust function on LCD panel
During printing using MK3, I can change some parameter like printing temperature, moving speed real-time on LCD panel. Is it possible that I can connect a computer and write some command to adjust some basic value like moving speed or flow(extrusion) rate?
This topic was modified 7 years temu by Eric.jin
Opublikowany : 29/05/2019 3:05 am
RE: how to use computer script/command to realize the adjust function on LCD panel
Triggered by what?
There are ways using Octoprint, I think. Or you can insert commands into the gcode file triggered by layer count or build height . All depends on why and when you want to make changes. Never tried making changes using Pronterface during a print... you could always hook up a PC and try it.
Opublikowany : 29/05/2019 7:36 pm
