how to use computer script/command to realize the adjust function on LCD panel
Eric.jin
(@zeqing-jin)
During printing using MK3, I can change some parameter like printing temperature, moving speed real-time on LCD panel. Is it possible that I can connect a computer and write some command to adjust some basic value like moving speed or flow(extrusion) rate?
Este debate ha sido modificado el hace 7 years por Eric.jin
Respondido : 29/05/2019 3:05 am
RE: how to use computer script/command to realize the adjust function on LCD panel
Triggered by what?
There are ways using Octoprint, I think.  Or you can insert commands into the gcode file triggered by layer count or build height .   All depends on why and when you want to make changes.  Never tried making changes using Pronterface during a print... you could always hook up a PC and try it.
Respondido : 29/05/2019 7:36 pm
