Horrible Z-Axis Sounds
aaron.h12
(@aaron-h12)
Hello All,
My mk3 is making a terrible sound from the Z-Axis. The other forums I have read always tell the OP to post a video as it is generally a unique sound. So My apologies if it has already been answered. But please take a listen and let's put our heads together to solve this horrible noise. I'm sure it cant be good for it.
Here's the video:
Thanks for you helps!
Publié : 12/04/2018 3:46 am
rob.l6
(@rob-l6)
Re: Horrible Z-Axis Sounds
Sounds like your z axis could do with some alignment tweaks perhaps. Also, perhaps change the support base for the printer (there are a few good threads about sound/vibration deadening around). I doubt whether it's anything more serious than that. I think most do it to some degree. Mine does but it's not particularly loud.
Good luck.
Publié : 12/04/2018 5:41 am
aaron.h12
(@aaron-h12)
Thank you for you comment! I will try to level the X-Axis. I tried before I took the video by running it all the way up until it leveled out but that seemed to make things worse!
Also I do have the rubber feets on now but that might not be good enough.
Publié : 12/04/2018 5:44 am
rob.l6
(@rob-l6)
Also, can you tell if the sound originates more from one side?
Publié : 12/04/2018 5:50 am
aaron.h12
(@aaron-h12)
Yes I think more so from the right side and moreover the power supply seems to raddle.
Publié : 12/04/2018 6:12 am
aaron.h12
(@aaron-h12)
Ah much better, after making the modifications you suggested, the noise is virtually gone. I can still hear it a bit but I no longer think it is going to self destruct. Thank you for your help tonight. 😀
Publié : 12/04/2018 6:23 am
rob.l6
(@rob-l6)
No problem. Happy printing 🙂
Publié : 12/04/2018 9:52 am
stahlfabrik
(@stahlfabrik)
What did you change?
Publié : 12/04/2018 12:57 pm
Crunch
(@crunch)
I now have the same sound as your video sound appears to come from right z axis motor. Tried holding it in different pkaces to try to deaden the sound but no luck so far
The Latest Firmware can be found here https://github.com/prusa3d/Prusa-Firmware/releases
Open Firmware Issues https://github.com/prusa3d/Prusa-Firmware/issues
Publié : 14/04/2018 8:14 pm
Martin Wolfe
(@martin-wolfe)
Hello,
I used to have the same sound problem. What solved it for me was slackening very slightly the screws that hold the trapezoidal nuts to the x-ends. It is an alignment problem when the top of the x-end is not flat/perpendicular to the z-axis rods and threaded rods the slight slackening allows the nut to alight properly.
A long term solution would be to redesign the nut pockets in the X-ends to take nylock nuts so that even when slackened they will not slip and the calibration will not drift as a result. As it stands with slight slackening you should not losten too much.
Hope this helps,
Martin
Martin Wolfe
Publié : 14/04/2018 8:48 pm
