[Résolu] Heatbed resistance 4 ohms - problem?
FlyingCog
(@flyingcog)
I accidentally scratched the heatbed and was instructed by the support to touch it with acrylic paint. After first calibration the heatbed did not heated properly and I found the instructions to check the resistance. When I disassebled the cable holder I found out that one of the screws holding VCC or GND (I don't remember which) got loose and there was no contact).
I fixed the contact but while I was there I measured the resistance. It was 4 ohm between screws not 3.4. The prints come out fine but will the extra 0.6 of resistance cause any problems or is it within expected boundaries?
Best Answer by JoanTabb:
Hi Flying cog,
when measuring very low resistances meter leads often affect the value. this may be one of those instances.
Publié : 04/08/2021 8:13 am
Meter leading you astray
Hi Flying cog,
Publié : 04/08/2021 4:21 pm
1 personnes ont aimé
