Headbed material? What is used as lamination material?
MTom
 MTom
(@mtom)
does anybody know what is used as lamination on the metal sheet ?
I am looking for a heat resistant (250°) transparent, flexible material for a totally different use. The heatbed just came to my mind as
one side of mine got peeled off, cause I was scratching too much.
thanks
Opublikowany : 27/07/2020 6:30 pm
RE: Headbed material? What is used as lamination material?
Do you mean the PEI surface? I believe Prusa uses 3M adhesive. I don't think it's rated to 250C.
Opublikowany : 27/07/2020 6:37 pm
MTom
 MTom
(@mtom)
Yes you are right I had the head temperatures in mind.
Opublikowany : 28/07/2020 8:04 am
@thomas-m83,
as far as I know, Prusa uses 3M 468MP or similar adhesive film. This is sufficiently heat-resistant for the max. bed temperature of the i3 printer (122 degrees C.). I believe the max. Temp. resistance of the adhesive film and the magnetic adhesive is 150 degrees C.
Opublikowany : 28/07/2020 8:17 pm
