First layer problem
Agentu
(@agentu)
First layer problem
I have some problems with my MK3s printer.After i had successful prints for over a year suddenly i have problems with first layer.Whenever the head change direction the filament curl up and get stuck to the nozzle growing it to a blob.For this reason i cant print supports.Ive tried to wash the PEI with isopropyl alcohol, with acetone and with warm water and dish soap.I tried differently Live Z and hotend and bed temperature.Does anybody had this problem before? I have to ask before i disassembly the x-carrier , maybe the solution is much simpler.Thank You.
Posted : 27/12/2020 5:05 pm
Agentu
(@agentu)
RE: First layer problem
I forgot to say that i have this problem with PLA and PETG.I use the presets for Generic PLA and PETG from PrusaSlicer.
Posted : 27/12/2020 5:07 pm
Wash, rinse dry. no ipa, no glue no hairspray...
then set liveZ
test patch files at bottom of first post
Posted : 27/12/2020 7:11 pm
Peter M
(@peter-m)
Clean bed with dish soap.
Adjust your first layer, start to high and go lower in steps. Print a big flat square or a few square and check if it works.
On the pei sheet, if you go to low filament will release.(powder coated sheet needs to go a little lower).
Bed 10 degrees higher helps.
7x7 calibration in the printer settings is better then the default.
Posted : 28/12/2020 12:07 am
Agentu
(@agentu)
I washed the PEI with hot water and dish soap (again 😀 ), but this time i used a dish sponge, i heated the hotend and used the needle from Prusa kit to clean the nozzle, although it came clean and now i can use my printer again.Thank you all for reply.
Posted : 28/12/2020 8:14 am
