[Rozwiązany] Firmware upgrade stuck
Johan
(@johan-5)
I have just gotten my Prusa Original MK3S and try to upgrade the firmware with the latest.
First I had some trouble getting my Mac to communicate on the com port (when I hit the Flash button) but after some tries it began to upgrade.
After maybe 15 seconds (about 1/5 on the progressbar) the log says:
Writing | #################################avrdude-slic3r: stk500v2_recv(): timeout
avrdude-slic3r: stk500v2_getsync(): timeout communicating with programmer
avrdude-slic3r: stk500v2_command(): failed miserably to execute command 0x06
avrdude-slic3r: stk500v2_loadaddr(): failed to set load address
Now the display on the printer reads "Upgrading firmware Do not disconnect!" and a star moving back and forth.
It has been like that for about 15 minutes now. How long should it take?
Any suggestions on how to proceed?
This topic was modified 6 years temu by Johan
Opublikowany : 12/06/2020 3:11 pm
Johan
(@johan-5)
RE: Firmware upgrade stuck
My computer restarted after an update and when I tried it again it worked. 3.9.0 now installed. 🙂
Opublikowany : 12/06/2020 5:14 pm
