[Solved] Firmware upgrade stuck
Johan
(@johan-5)
I have just gotten my Prusa Original MK3S and try to upgrade the firmware with the latest.
First I had some trouble getting my Mac to communicate on the com port (when I hit the Flash button) but after some tries it began to upgrade.
After maybe 15 seconds (about 1/5 on the progressbar) the log says:
Writing | #################################avrdude-slic3r: stk500v2_recv(): timeout
avrdude-slic3r: stk500v2_getsync(): timeout communicating with programmer
avrdude-slic3r: stk500v2_command(): failed miserably to execute command 0x06
avrdude-slic3r: stk500v2_loadaddr(): failed to set load address
Now the display on the printer reads "Upgrading firmware Do not disconnect!" and a star moving back and forth.
It has been like that for about 15 minutes now. How long should it take?
Any suggestions on how to proceed?
This topic was modified před 6 years by Johan
Napsal : 12/06/2020 3:11 pm
Johan
(@johan-5)
RE: Firmware upgrade stuck
My computer restarted after an update and when I tried it again it worked. 3.9.0 now installed. 🙂
Napsal : 12/06/2020 5:14 pm
