Firmware update failure (com port)
Jeffrey Benson
(@jeffrey-benson)
I'm getting an firmware error when trying to flash over the network to my rpi Prusa mk3s+.  I've tried restarting everything and tried multiple times, but no luck.  The log is below:
avrdude-slic3r -v -p atmega2560 -c wiring -P COM1 -b 115200 -D -U flash:w:0:C:\Users\jsben\Downloads\prusa3d_fw_3_12_2_MK3S\prusa3d_fw_MK3S_MK3S+_3_12_2_5713.hex:i
avrdude-slic3r: Version 6.3-20160220-prusa3d, compiled on Mar 15 2023 at 12:46:47
                Copyright (c) 2000-2005 Brian Dean,  http://www.bdmicro.com/
                Copyright (c) 2007-2014 Joerg Wunsch
                Using Port                    : COM1
                Using Programmer              : wiring
                Overriding Baud Rate          : 115200
avrdude-slic3r: stk500v2_recv(): timeout
avrdude-slic3r: stk500v2_getsync(): timeout communicating with programmer
avrdude-slic3r: Could not open port: COM1
avrdude-slic3r done.  Thank you.
Publié : 24/03/2023 2:55 am
RE: Firmware update failure (com port)
Firmware updates for the MKx series I would execute via PrusaSlicer:
wbr,
Karl
Publié : 24/03/2023 9:28 am
LingChristian
(@lingchristian)
Same here, tried to put on an MK3S via PrusaSlicer 2.5.1 the FW 3.12.2 and caused massive error.
Now on reboot the screen sometimes doesnt show anything and a permanent beep is notcieable .. so guess the FW fried something.
Factory Reset isn´t possible ( https://help.prusa3d.com/article/factory-reset-mk2s-mk2-5s-mk3s_2216 )
BTW: No, nothing on my Laptop has rebooted, no cable where disconnected, everything went normal as the ten times before, exept it didn´t come over the 4%
Any ideas?
Publié : 24/03/2023 3:11 pm
Jeffrey Benson
(@jeffrey-benson)
No ideas.  I didn't even make it to the flash screen on the printer.  It just fails in PrusaSlicer when I try to flash.  It probably has something to do with the port, but there's no other ports to choose from other than 3.
Publié : 24/03/2023 9:40 pm
Jeffrey Benson
(@jeffrey-benson)
That's where it fails.  I think it has something to do with the assigned port, which can't be changed to any others, because I don't get any indication of a flash on the Prusa screen.  It fails in the slicer when trying to connect to it.
Publié : 24/03/2023 9:42 pm
LingChristian
(@lingchristian)
Well, after about 25 reboots of the printer and reconnect attempts the Slicer found the printer and was able to put the newer FW on.
The weird thing, I didn´t changed anything in the setup and did any of these steps few times before ... so it leaves an ungood feeling, but it works for now.
Funfact: the loud permanent 'Beep' of the Prusa Mk3S triggered my smoke detector in a strange way, so I got a message on my phone, that I should check my flat for fire or smoke.
Publié : 25/03/2023 9:09 am
Was it Alexa that sent the message?
Maybe she didn't like the noise!
Joan
Publié : 25/03/2023 9:54 am
It may help if you temporarily disable the Bluetooth interface on the PC and use a USB2 port instead of USB3.
wbr,
Karl
Publié : 26/03/2023 2:15 am
2 personnes ont aimé
Pony Pirate
(@pony-pirate)
Membre
Thank you Karl - I was having this issue.
Turned off the bluetooth on my laptop. Still had the flash error.
Changed USB ports & the flash was successful!
Now to turn the bluetooth back on before I forget why my external speakers won't connect 😀
Heather
Publié : 07/08/2023 1:17 am
happy printing!
wbr,
Karl
Publié : 07/08/2023 10:09 pm
