Firmware seems to flash fine, Validation is failing though (3.10.1)
Flo1988
(@flo1988)
i updated my firmware on my MK3S however the validation in Prusa Slicer gives me a "flashing failed" error back with the validation failed in the log.
The Printer itself shows no problems so far, so i would tend to ignore it. The printer is showing 3.10.1 in the support menu.
Maybe someone had a similar issue, I found different issues in the forum.
Here's the log from the flash:
avrdude-slic3r -v -p atmega2560 -c wiring -P COM4 -b 115200 -D -U flash:w:0:C:\Users\kingh\Downloads\prusa3d_fw_3_10_1_MK3S\prusa3d_fw_MK3S_MK3S+_3_10_1_4697.hex:i
avrdude-slic3r: Version 6.3-20160220-prusa3d, compiled on Dec 21 2021 at 17:14:48
                Copyright (c) 2000-2005 Brian Dean,  http://www.bdmicro.com/
                Copyright (c) 2007-2014 Joerg Wunsch
                Using Port                    : COM4
                Using Programmer              : wiring
                Overriding Baud Rate          : 115200
                AVR Part                      : ATmega2560
                Chip Erase delay              : 9000 us
                PAGEL                         : PD7
                BS2                           : PA0
                RESET disposition             : dedicated
                RETRY pulse                   : SCK
                serial program mode           : yes
                parallel program mode         : yes
                Timeout                       : 200
                StabDelay                     : 100
                CmdexeDelay                   : 25
                SyncLoops                     : 32
                ByteDelay                     : 0
                PollIndex                     : 3
                PollValue                     : 0x53
                Memory Detail                 :
                                         Block Poll               Page                       Polled
                  Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
                  eeprom        65    10     8    0 no       4096    8      0  9000  9000 0x00 0x00
                  flash         65    10   256    0 yes    262144  256   1024  4500  4500 0x00 0x00
                  lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                  hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                  efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                  lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                  calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
                  signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
                Programmer Type : Wiring
                Description     : Wiring
                Programmer Model: AVRISP
                Hardware Version: 15
                Firmware Version Master : 2.10
                Vtarget         : 0.0 V
                SCK period      : 0.1 us
avrdude-slic3r: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude-slic3r: Device signature = 0x1e9801 (probably m2560)
avrdude-slic3r: safemode: hfuse reads as D0
avrdude-slic3r: safemode: efuse reads as FD
avrdude-slic3r: reading input file "C:\Users\kingh\Downloads\prusa3d_fw_3_10_1_MK3S\prusa3d_fw_MK3S_MK3S+_3_10_1_4697.hex"
avrdude-slic3r: writing flash (251278 bytes):
Writing | ####################################avrdude-slic3r: stk500v2_recv(): timeout
### | 100% 54.93s
avrdude-slic3r: 251278 bytes of flash written
avrdude-slic3r: verifying flash memory against C:\Users\kingh\Downloads\prusa3d_fw_3_10_1_MK3S\prusa3d_fw_MK3S_MK3S+_3_10_1_4697.hex:
avrdude-slic3r: load data flash data from input file C:\Users\kingh\Downloads\prusa3d_fw_3_10_1_MK3S\prusa3d_fw_MK3S_MK3S+_3_10_1_4697.hex:
avrdude-slic3r: input file C:\Users\kingh\Downloads\prusa3d_fw_3_10_1_MK3S\prusa3d_fw_MK3S_MK3S+_3_10_1_4697.hex contains 251278 bytes
avrdude-slic3r: reading on-chip flash data:
Reading | ########avrdude-slic3r: stk500v2_recv(): timeout
##### | 100% 87.33s
avrdude-slic3r: verifying ...
avrdude-slic3r: verification error, first mismatch at byte 0xa711
                0x60 != 0x94
avrdude-slic3r: verification error; content mismatch
avrdude-slic3r: safemode: Fuses OK (E:FD, H:D0, L:FF)
avrdude-slic3r done.  Thank you.
Posted : 23/01/2022 4:46 pm
