Firmware 3.4.0 FSensor Message and printer pauses
Cowwolfe
(@cowwolfe)
I upgraded my Prusa MK3 to firmware 3.4.0 and now I'm getting an occasional message in octoprint and while it happens the printer pauses. I've not seen this before the 3.4.0 upgrade.
It appears to happen when the printer is doing repeated short infill movements (about 3-5 mm strokes)
From Octoprint:
Send: N19400 G1 X178.757 Y111.361 E0.01548*104
Recv: ok
Send: N19401 G1 X175.739 Y108.343 E0.11151*105
Recv: ok
Send: N19402 G1 X175.739 Y107.751 E0.01548*111
Recv: fsensor_stop_and_save_print
Recv: fsensor_oq_meassure_start
Recv: echo:Enqueing to the front: "G1 E-3 F200"
Recv: echo:Enqueing to the front: "G1 E3 F200"
Recv: fsensor_oq_meassure_stop, 4 samples
Recv: st_sum=716 yd_sum=120 er_sum=0 er_max=0
Recv: yd_min=40 yd_max=27 yd_avg=30 sh_avg=17
Recv: fsensor_err_cnt = 0
Recv: fsensor_restore_print_and_continue
Recv: Resend: 19383
Recv: ok
Send: N19383 G1 X184.139 Y113.188 E0.01548*110
Recv: ok
Send: N19384 G1 X188.144 Y117.194 E0.14798*109
Recv: ok
Eric Z.
Napsal : 23/09/2018 6:12 pm
Nebulus
(@nebulus)
Re: Firmware 3.4.0 FSensor Message and printer pauses
I'm also having issues after 3.4 upgrade, pauses... filament sensor messages, and even nozzle crash into the print 🙁
Napsal : 23/09/2018 6:44 pm
Cowwolfe
(@cowwolfe)
So far, one print worked (still printing other), with no physical print issues... just the pausing.
Eric Z.
Napsal : 23/09/2018 6:59 pm
Brad Cozine
(@brad-cozine)
Just had to disable my filament sensor because if this issue. Using Hatchbox PLA Gold.
Napsal : 01/10/2018 4:02 pm
TomVe
(@tomve)
Same here. I now have to run with filament sensor disabled. I never had any problems with it before 3.4.0.
Napsal : 02/10/2018 11:38 pm
matteosacco
(@matteosacco)
Same here ... i will try to disable this sensor ...no problem before ...very frustrating
Napsal : 07/10/2018 9:41 pm
dret
 dret
(@dret)
Rec - fsensor_stop_and_save_print - and printer pauses during OctoPrint on short infill segments also.
Disabled Filament sensor and pauses/message stopped.
prusa3d_fw_3_4_0_MK3
White Inland PLA building a <1cm wall (10% rec fill)
Napsal : 07/10/2018 9:57 pm
z0mb13k1ll
(@z0mb13k1ll)
RE: Firmware 3.4.0 FSensor Message and printer pauses
was this issue fixed in recent firmwares? I am still back on 3.5.0 and just had this issue for the first time ever and i've printed a lot of small stuff before. had to disable the sensor so it would print proper.
Napsal : 25/02/2020 2:11 am
