[Resuelto] Firmware 3.7.1 and 3.7.2 language change not possible
since i tried Firmware 3.7.1 and 3.7.2 i have no luck with change to another language. After i have select another language, printer asks me to copy selected language., selected yes -> blinking 3 times the text "Original Prusa  i3 Prusa Research language update..." -> nothing happens. I am back again in the language selction menu. I tried this several times, but always the same result.
I tried also:
- checked all connections cable for breaks and loose contacts -> nothing, all connections are fine
- total factory reset and new several flashattempts-> no luck
- flashed with newest Slicer v2.0.0 -> no luck
- tried with serveral Arduino IDE in Windows and Ubuntu -> no luck
When flashing in Linux with build.sh i am wondering about serveral output warnings in the log file (see attachement).
System is running, but i cannot change the language. It seems to me there is an hardware issue on the board or there are same software changes anywhere.... V 3.7.0 and earlier are ok, no problems with changing language.
with best regards
Karl
/attachement) build.sh:
HEX-Dateien werden geschrieben -> /home/admin/Schreibtisch/MK3-Firmware/Prusa-Firmware-3.7.2/lang/
und (NAS-DISKSTATION) -> /run/user/1001/gvfs/smb-share:server=192.168.0.17,share=raspberry,user=admin/Prusa_Mk3_Firmware_Flashfiles/
Log-Datei -> /home/admin/Schreibtisch/build.log
kgolger - 08.07.2019
/home/admin/Schreibtisch/MK3-Firmware/Prusa-Firmware-3.7.2/build.sh gestartet:
Picked up JAVA_TOOL_OPTIONS:
Loading configuration...
Initializing packages...
Preparing boards...
Verifying...
Sketch uses 252122 bytes (99%) of program storage space. Maximum is 253952 bytes.
Global variables use 6142 bytes of dynamic memory.
lang-build.sh started
lang=en
count=311
offs=638
size=8838
awk: line 2: function strtonum never defined
./lang-build.sh: 121: ./lang-build.sh: arithmetic expression: expecting EOF: "0x"
lang=cz
[E]: Text "\x1b[2JPOZOR:\x1b[1;0HCrash detekce\x1b[2;0Hdeaktivovana ve\x1b[3;0HStealth modu" is longer then definiton on line 17
[E]: Text "Dostavovani Z:" is longer then definiton on line 25
[E]: Text "a stisknete tlacitko" is longer then definiton on line 41
[E]: Text "SpoolJoin [zap]" is longer then definiton on line 49
[E]: Text "SpoolJoin [vyp]" is longer then definiton on line 57
[E]: Text "AutoZavedeni fil." is longer then definiton on line 65
[E]: Text "Automaticke zavadeni filamentu je dostupne pouze pri zapnutem filament senzoru..." is longer then definiton on line 69
[E]: Text "Automaticke zavadeni filamentu aktivni, stisknete tlacitko a vlozte filament..." is longer then definiton on line 73
[E]: Text "Korekce E:" is longer then definiton on line 217
[E]: Text "Vysunout filament" is longer then definiton on line 221
[E]: Text "Kon. spinac nesepnut" is longer then definiton on line 233
[E]: Text "F. autozav. [zap]" is longer then definiton on line 273
[E]: Text "F. autozav. [N/A]" is longer then definiton on line 277
[E]: Text "F. autozav. [vyp]" is longer then definiton on line 281
[E]: Text "Rychlost vent." is longer then definiton on line 289
[E]: Text "Kontr. vent.[zap]" is longer then definiton on line 297
[E]: Text "Kontr. vent.[vyp]" is longer then definiton on line 301
[E]: Text "Filament nezaveden" is longer then definiton on line 325
[E]: Text "Spotrebovano filamentu" is longer then definiton on line 333
[E]: Text "Kal. prvni vrstvy" is longer then definiton on line 349
[E]: Text "Predni tiskovy vent?" is longer then definiton on line 369
[E]: Text "Levy vent na trysce?" is longer then definiton on line 505
[E]: Text "Predehrejte trysku!" is longer then definiton on line 785
[E]: Text "RPi port [zap]" is longer then definiton on line 889
[E]: Text "RPi port [vyp]" is longer then definiton on line 893
[W]: No display definition on line 9
[W]: No display definition on line 21
[W]: No display definition on line 37
[W]: No display definition on line 53
[W]: No display definition on line 61
[W]: No display definition on line 77
[W]: No display definition on line 81
[W]: No display definition on line 85
[W]: No display definition on line 89
[W]: No display definition on line 93
[W]: No display definition on line 97
[W]: No display definition on line 105
[W]: No display definition on line 117
[W]: No display definition on line 121
[W]: No display definition on line 125
[W]: No display definition on line 145
[W]: No display definition on line 149
[W]: No display definition on line 153
[W]: No display definition on line 157
[W]: No display definition on line 161
[W]: No display definition on line 165
[W]: No display definition on line 169
[W]: No display definition on line 173
[W]: No display definition on line 177
[W]: No display definition on line 181
[W]: No display definition on line 189
[W]: No display definition on line 193
[W]: No display definition on line 205
[W]: No display definition on line 225
[W]: No display definition on line 237
[W]: No display definition on line 241
[W]: No display definition on line 253
[W]: No display definition on line 265
[W]: No display definition on line 269
[W]: No display definition on line 285
[W]: No display definition on line 305
[W]: No display definition on line 309
[W]: No display definition on line 313
[W]: No display definition on line 317
[W]: No display definition on line 357
[W]: No display definition on line 361
[W]: No display definition on line 365
[W]: No display definition on line 377
[W]: No display definition on line 381
[W]: No display definition on line 385
[W]: No display definition on line 393
[W]: No display definition on line 401
[W]: No display definition on line 405
[W]: No display definition on line 409
[W]: No display definition on line 469
[W]: No display definition on line 473
[W]: No display definition on line 497
[W]: No display definition on line 501
[W]: No display definition on line 509
[W]: No display definition on line 517
[W]: No display definition on line 521
[W]: No display definition on line 529
[W]: No display definition on line 541
[W]: No display definition on line 549
[W]: No display definition on line 557
[W]: No display definition on line 569
[W]: No display definition on line 573
[W]: No display definition on line 577
[W]: No display definition on line 581
[W]: No display definition on line 589
[W]: No display definition on line 593
[W]: No display definition on line 597
[W]: No display definition on line 601
[W]: No display definition on line 605
[W]: No display definition on line 609
[W]: No display definition on line 613
[W]: No display definition on line 617
[W]: No display definition on line 621
[W]: No display definition on line 625
[W]: No display definition on line 629
[W]: No display definition on line 633
[W]: No display definition on line 637
[W]: No display definition on line 641
[W]: No display definition on line 645
[W]: No display definition on line 649
[W]: No display definition on line 653
[W]: No display definition on line 657
[W]: No display definition on line 661
[W]: No display definition on line 677
[W]: No display definition on line 685
[W]: No display definition on line 689
[W]: No display definition on line 693
[W]: No display definition on line 725
[W]: No display definition on line 753
[W]: No display definition on line 781
[W]: No display definition on line 789
[W]: No display definition on line 797
[W]: No display definition on line 805
[W]: No display definition on line 813
[W]: No display definition on line 817
[W]: No display definition on line 825
[W]: No display definition on line 829
[W]: No display definition on line 837
[W]: No display definition on line 845
[W]: No display definition on line 849
[W]: No display definition on line 865
[W]: No display definition on line 869
[W]: No display definition on line 873
[W]: No display definition on line 877
[W]: No display definition on line 909
[W]: No displ[E]: Text "Stav konc. spin." is longer then definiton on line 961
[E]: Text "Nektere soubory nebudou setrideny. Maximalni pocet souboru ve slozce pro setrideni je 100." is longer then definiton on line 969
[E]: Text "Trideni [Zadne]" is longer then definiton on line 973
[E]: Text "Trideni [cas]" is longer then definiton on line 977
[E]: Text "Trideni [Abeceda]" is longer then definiton on line 985
[E]: Text "Zvuk [hlasity]" is longer then definiton on line 993
[E]: Text "Zvuk [vypnuto]" is longer then definiton on line 1001
[E]: Text "Zvuk [jednou]" is longer then definiton on line 1009
[E]: Text "Zvuk [tichy]" is longer then definiton on line 1013
[E]: Text "Teplot. kalibrace" is longer then definiton on line 1061
[E]: Text "Je potreba kalibrovat osu Z. Prosim postupujte dle prirucky, kapitola Zaciname, sekce Postup kalibrace." is longer then definiton on line 1081
[E]: Text "Vyjmout filament" is longer then definiton on line 1113
[E]: Text "Pouzite behem tisku" is longer then definiton on line 1125
ay definition on line 917
[W]: No display definition on line 921
[W]: No display definition on line 929
[W]: No display definition on line 933
[W]: No display definition on line 945
[W]: No display definition on line 949
[W]: No display definition on line 957
[W]: No display definition on line 965
[W]: No display definition on line 981
[W]: No display definition on line 997
[W]: No display definition on line 1005
[W]: No display definition on line 1017
[W]: No display definition on line 1029
[W]: No display definition on line 1033
[W]: No display definition on line 1037
[W]: No display definition on line 1041
[W]: No display definition on line 1045
[W]: No display definition on line 1073
[W]: No display definition on line 1085
[W]: No display definition on line 1089
[W]: No display definition on line 1093
[W]: No display definition on line 1097
[W]: No display definition on line 1101
[W]: No display definition on line 1105
[W]: No display definition on line 1109
[W]: No display definition on line 1121
[W]: No display definition on line 1133
[W]: No display definition on line 1137
[W]: No display definition on line 1149
[W]: No display definition on line 1169
[W]: No display definition on line 1185
[W]: No display definition on line 1201
[W]: No display definition on line 1221
[W]: No display definition on line 1225
[W]: No display definition on line 1229
[W]: No display definition on line 1233
[W]: No display definition on line 1237
[W]: No display definition on line 1241
count=311
offs=638
size=8826
lang=de
[E]: Text "\x1b[2JWARNUNG:\x1b[1;0HCrash Erkennung\x1b[2;0Hdeaktiviert im\x1b[3;0HStealth Modus" is longer then definiton on line 17
[E]: Text "Z Einstellung:" is longer then definiton on line 25
[E]: Text "Sind linke+rechte Z- Schlitten ganz oben?" is longer then definiton on line 45
[E]: Text "SpoolJoin [an]" is longer then definiton on line 49
[E]: Text "SpoolJoin [aus]" is longer then definiton on line 57
[E]: Text "Auto-Laden Filament" is longer then definiton on line 65
[E]: Text "Automatisches Laden Filament nur bei einge schaltetem Filament- sensor verfuegbar..." is longer then definiton on line 69
[E]: Text "Automatisches Laden Filament ist aktiv, Knopf druecken und Filament einlegen..." is longer then definiton on line 73
[E]: Text "Z-Kal. fehlgeschlg. Sensor nicht ausgeloest. Schmutzige Duese? Warte auf Reset." is longer then definiton on line 101
[E]: Text "E-Korrektur:" is longer then definiton on line 217
[E]: Text "Ende nicht getroffen" is longer then definiton on line 233
[E]: Text "Extruder Luefter:" is longer then definiton on line 257
[E]: Text "F.Autoladen [an]" is longer then definiton on line 273
[E]: Text "F. Autoload [nv]" is longer then definiton on line 277
[E]: Text "F. Autoload [aus]" is longer then definiton on line 281
[E]: Text "Luefter-Tempo" is longer then definiton on line 289
[E]: Text "Luefter Chk. [an]" is longer then definiton on line 297
[E]: Text "Luefter Chk.[aus]" is longer then definiton on line 301
[E]: Text "Fil. nicht geladen" is longer then definiton on line 325
[E]: Text "Datei unvollstaendig Trotzdem fortfahren?" is longer then definiton on line 341
[E]: Text "Erste-Schicht Kal." is longer then definiton on line 349
[E]: Text "PID Kal. " is longer then definiton on line 697
[E]: Text "PID Kalibrierung" is longer then definiton on line 705
[E]: Text "Druck wiederherst " is longer then definiton on line 857
[E]: Text "Entfernen Sie das alte Filament und druecken Sie den Knopf, um das neue zu laden." is longer then definiton on line 861
[E]: Text "RPi Port [an]" is longer then definiton on line 889
[E]: Text "RPi Port [aus]" is longer then definiton on line 893
[W]: No displ[E]: Text "Selbsttest misslung " is longer then definiton on line 937
[E]: Text "Endschalter Status" is longer then definiton on line 961
[E]: Text "Sort. [Keine]" is longer then definiton on line 973
[E]: Text "Sort. [Zeit]" is longer then definiton on line 977
[E]: Text "Sort. [Alphabet]" is longer then definiton on line 985
[E]: Text "Sound [laut]" is longer then definiton on line 993
[E]: Text "Sound [stumm]" is longer then definiton on line 1001
[E]: Text "Sound [einmal]" is longer then definiton on line 1009
[E]: Text "Sound [leise]" is longer then definiton on line 1013
[E]: Text "Temp. kalibrieren" is longer then definiton on line 1061
[E]: Text "Es ist noch notwendig die Z-Kalibrierung auszufuehren. Bitte befolgen Sie das Handbuch, Kapitel Erste Schritte, Abschnitt Kalibrierablauf." is longer then definiton on line 1081
[E]: Text "Filament entladen" is longer then definiton on line 1113
[E]: Text "Beim Druck benutzt" is longer then definiton on line 1125
count=311
offs=638
size=9880
lang=es
[E]: Text "\x1b[2JATENCION:\x1b[1;0HDec. choque\x1b[2;0Hdesactivada en\x1b[3;0HModo silencio" is longer then definiton on line 17
[E]: Text "Carros Z izq./der. estan arriba maximo?" is longer then definiton on line 45
[E]: Text "Carga automatica de filamento" is longer then definiton on line 65
[E]: Text "La carga automatica de filamento solo funciona si el sensor de filamento esta activado..." is longer then definiton on line 69
[E]: Text "La carga automatica de filamento esta activada, pulse el dial e inserte el filamento..." is longer then definiton on line 73
[E]: Text "Estado de la correa" is longer then definiton on line 109
[E]: Text "E-correcion:" is longer then definiton on line 217
[E]: Text "Expulsar filamento" is longer then definiton on line 221
[E]: Text "Expulsando filamento" is longer then definiton on line 229
[E]: Text "Endstop no alcanzado" is longer then definiton on line 233
[E]: Text "Ventilador del extrusor:" is longer then definiton on line 257
[E]: Text "Informacion del extrusor" is longer then definiton on line 261
[E]: Text "Autocarg.Fil[act]" is longer then definiton on line 273
[E]: Text "Autocarg.Fil[N/D]" is longer then definiton on line 277
[E]: Text "Autocarg.Fil[ina]" is longer then definiton on line 281
[E]: Text "Velocidad Vent." is longer then definiton on line 289
[E]: Text "Comprob.vent[act]" is longer then definiton on line 297
[E]: Text "Comprob.vent[ina]" is longer then definiton on line 301
[E]: Text "Fil. no introducido" is longer then definiton on line 325
[E]: Text "Sensor de filamento" is longer then definiton on line 329
[E]: Text "Archivo incompleto. ?Continuar de todos modos?" is longer then definiton on line 341
[E]: Text "Cal. primera cap." is longer then definiton on line 349
[E]: Text "Calentamiento acabado." is longer then definiton on line 389
[E]: Text "Comprobando los sensores" is longer then definiton on line 429
[E]: Text "Introducir filamento" is longer then definiton on line 477
[E]: Text "?Esta colocada la lamina de acero sobre la base?" is longer then definiton on line 493
[E]: Text "Izquierda [um]" is longer then definiton on line 513
[E]: Text "Introducir filam." is longer then definiton on line 525
[E]: Text "Introduciendo filam." is longer then definiton on line 533
[E]: Text "Ventilador no gira" is longer then definiton on line 665
[E]: Text "Se han encontrado ajustes anteriores. Se ajustara el PID, los pasos del extrusor, etc" is longer then definiton on line 681
[E]: Text "Colocar una hoja de papel sobre la superficie de impresion durante la calibracion de los primeros 4 puntos. Si la boquilla mueve el papel, apagar impresora inmediatamente." is longer then definiton on line 713
[E]: Text "Por favor abate el rodillo de empuje (idler) y retira el filamento manualmente." is longer then definiton on line 741
[E]: Text "Precalienta extrusor!" is longer then definiton on line 785
[E]: Text "Impresion cancelada" is longer then definiton on line 809
[E]: Text "Ventilador del fusor:" is longer then definiton on line 821
[E]: Text "Recuperando impresion" is longer then definiton on line 857
[E]: Text "Retire el filamento viejo y presione el dial para comenzar a cargar el nuevo filamento." is longer then definiton on line 861
[E]: Text "Resumiendo impresion" is longer then definiton on line 881
[E]: Text "Puerto RPi [act]" is longer then definiton on line 889
[E]: Text "Puerto RPi [ina]" is longer then definiton on line 893
[W]: No displ[E]: Text "Mostrar endstops" is longer then definiton on line 961
[E]: Text "Algunos archivos no se ordenaran. Maximo 100 archivos por carpeta para ordenar. " is longer then definiton on line 969
[E]: Text "Ordenar [nada]" is longer then definiton on line 973
[E]: Text "Ordenar [Fecha]" is longer then definiton on line 977
[E]: Text "Ordenar [alfabet]" is longer then definiton on line 985
[E]: Text "Sonido [alto]" is longer then definiton on line 993
[E]: Text "Sonido[silenciad]" is longer then definiton on line 1001
[E]: Text "Sonido [una vez]" is longer then definiton on line 1009
[E]: Text "Sonido[silencios]" is longer then definiton on line 1013
[E]: Text "Ventilador girando" is longer then definiton on line 1021
[E]: Text "Calibracion temp." is longer then definiton on line 1061
[E]: Text "Todavia es necesario hacer una calibracion Z. Por favor siga el manual, capitulo Primeros pasos, seccion Calibracion del flujo." is longer then definiton on line 1081
[E]: Text "Soltar filamento" is longer then definiton on line 1113
[E]: Text "Usado en impresion" is longer then definiton on line 1125
[E]: Text "Detalles de calibracion XYZ" is longer then definiton on line 1177
[E]: Text "Intr. todos fil." is longer then definiton on line 1217
count=311
offs=638
size=9694
lang=fr
[E]: Text "\x1b[2JLa detection de crash peut etre\x1b[1;0Hactive seulement\x1b[2;0Hen mode Normal" is longer then definiton on line 13
[E]: Text "\x1b[2JATTENTION :\x1b[1;0HDetection de crash\x1b[2;0H desactivee en\x1b[3;0Hmode Furtif" is longer then definiton on line 17
[E]: Text "et pressez le bouton" is longer then definiton on line 41
[E]: Text "Z~carriages gauche + droite tout en haut?" is longer then definiton on line 45
[E]: Text "AutoCharge du filament" is longer then definiton on line 65
[E]: Text "Echec bed leveling. Capt. non declenche. Debris sur buse ? En attente d'un reset." is longer then definiton on line 101
[E]: Text "Statut courroie" is longer then definiton on line 109
[E]: Text "Correct-E:" is longer then definiton on line 217
[E]: Text "Ventilo extrudeur:" is longer then definiton on line 257
[E]: Text "Infos extrudeur" is longer then definiton on line 261
[E]: Text "ChargAuto f. [on]" is longer then definiton on line 273
[E]: Text "AutoCharg F [N/A]" is longer then definiton on line 277
[E]: Text "AutoCharg F [off]" is longer then definiton on line 281
[E]: Text "Vitesse ventil" is longer then definiton on line 289
[E]: Text "Verif ventilo[on]" is longer then definiton on line 297
[E]: Text "Verif venti [off]" is longer then definiton on line 301
[E]: Text "Filament extrude et avec bonne couleur ?" is longer then definiton on line 321
[E]: Text "Filament non charge" is longer then definiton on line 325
[E]: Text "Capteur de filament" is longer then definiton on line 329
[E]: Text "Temps d'impression" is longer then definiton on line 337
[E]: Text "Cal. 1ere couche" is longer then definiton on line 349
[E]: Text "Ventilo impr avant ?" is longer then definiton on line 369
[E]: Text "Change correctement?" is longer then definiton on line 413
[E]: Text "Verification du lit" is longer then definiton on line 417
[E]: Text "Verifications butees" is longer then definiton on line 421
[E]: Text "Verif. des capteurs" is longer then definiton on line 429
[E]: Text "Choisir extrudeur :" is longer then definiton on line 445
[E]: Text "Choix du filament :" is longer then definiton on line 449
[E]: Text "Inserez le filament" is longer then definiton on line 477
[E]: Text "Feuille d'acier sur plateau chauffant ?" is longer then definiton on line 493
[E]: Text "Ventilo tete gauche?" is longer then definiton on line 505
[E]: Text "Charger filament" is longer then definiton on line 525
[E]: Text "Chargement filament" is longer then definiton on line 533
[E]: Text "Calib. PID terminee" is longer then definiton on line 701
[E]: Text "Chauffe de la PINDA" is longer then definiton on line 709
[E]: Text "Prechauffez la buse!" is longer then definiton on line 785
[E]: Text "Impression en pause" is longer then definiton on line 833
[E]: Text "Carte SD [flashAir]" is longer then definiton on line 905
[W]: No displ[E]: Text "Echec de l'auto-test" is longer then definiton on line 937
[E]: Text "Tri : [aucun]" is longer then definiton on line 973
[E]: Text "Tri [heure]" is longer then definiton on line 977
[E]: Text "Tri [alphabet]" is longer then definiton on line 985
[E]: Text "Son [silencieux]" is longer then definiton on line 1013
[E]: Text "Calibration temp." is longer then definiton on line 1061
[E]: Text "Il y a encore besoin d'effectuer la calibration Z. Veuillez suivre le manuel, chapitre Premiers pas, section Processus de calibration." is longer then definiton on line 1081
[E]: Text "Details calib. XYZ" is longer then definiton on line 1177
count=311
offs=638
size=9865
lang=it
[E]: Text "\x1b[2JATTENZIONE:\x1b[1;0HRilev. impatto\x1b[2;0Hdisattivato in\x1b[3;0HModalita silenziosa" is longer then definiton on line 17
[E]: Text "e cliccare manopola" is longer then definiton on line 41
[E]: Text "Autocaric. filam." is longer then definiton on line 65
[E]: Text "Il caricamento automatico e attivo, premete la manopola e inserite il filamento..." is longer then definiton on line 73
[E]: Text "Livellamento letto fallito.NoRispSensore.Residui su ugello? In attesa di reset." is longer then definiton on line 101
[E]: Text "Stato delle cinghie" is longer then definiton on line 109
[E]: Text "C'e stato un Blackout. Recuperare la stampa?" is longer then definiton on line 113
[E]: Text "Correzione-E:" is longer then definiton on line 217
[E]: Text "Espelli filamento " is longer then definiton on line 221
[E]: Text "Espellendo filamento " is longer then definiton on line 229
[E]: Text "Finecorsa fuori portata" is longer then definiton on line 233
[E]: Text "Ventola estrusore:" is longer then definiton on line 257
[E]: Text "Info estrusore" is longer then definiton on line 261
[E]: Text "Autocar.filam[on]" is longer then definiton on line 273
[E]: Text "Autocar.fil.[N/A]" is longer then definiton on line 277
[E]: Text "Autocar.fil.[off]" is longer then definiton on line 281
[E]: Text "Velocita ventola" is longer then definiton on line 289
[E]: Text "Controllo ventole [on]" is longer then definiton on line 297
[E]: Text "Control.vent[off]" is longer then definiton on line 301
[E]: Text "Filamento estruso & con il giusto colore?" is longer then definiton on line 321
[E]: Text "Filamento utilizzato" is longer then definiton on line 333
[E]: Text "Finalizzando gli spostamenti" is longer then definiton on line 345
[E]: Text "Calibrazione primo layer." is longer then definiton on line 349
[E]: Text "Cambiato correttamente?" is longer then definiton on line 413
[E]: Text "Seleziona estrusore:" is longer then definiton on line 445
[E]: Text "Scegliere filamento:" is longer then definiton on line 449
[E]: Text "La piastra d'acciaio e sul piano riscaldato?" is longer then definiton on line 493
[E]: Text "Lato sinistro [um]" is longer then definiton on line 513
[E]: Text "Carica filamento" is longer then definiton on line 525
[E]: Text "Caricando filamento" is longer then definiton on line 533
[E]: Text "M117 Calibrazione primo layer." is longer then definiton on line 545
[E]: Text "Sono state trovate impostazioni vecchie. I valori di default di PID, Esteps etc. saranno impostati" is longer then definiton on line 681
[E]: Text "Calib. PID completa" is longer then definiton on line 701
[E]: Text "Calibrazione PID" is longer then definiton on line 705
[E]: Text "Riscaldamento PINDA" is longer then definiton on line 709
[E]: Text "Ventola di stampa:" is longer then definiton on line 821
[E]: Text "Rimuovi il filamento precedente e premi la manopola per caricare il nuovo filamento. " is longer then definiton on line 861
[E]: Text "Porta RPi [on]" is longer then definiton on line 889
[E]: Text "Porta RPi [off]" is longer then definiton on line 893
[W]: No displ[E]: Text "Imposta temperatura:" is longer then definiton on line 953
[E]: Text "Alcuni file non saranno ordinati. Il numero massimo di file in una cartella e 100 perche siano ordinati." is longer then definiton on line 969
[E]: Text "Ordina [none]" is longer then definiton on line 973
[E]: Text "Ordina [time]" is longer then definiton on line 977
[E]: Text "Ordine [alfabet]" is longer then definiton on line 985
[E]: Text "Suono [forte]" is longer then definiton on line 993
[E]: Text "Suono [mute]" is longer then definiton on line 1001
[E]: Text "Suono [singolo]" is longer then definiton on line 1009
[E]: Text "Suono[silenzioso]" is longer then definiton on line 1013
[E]: Text "E ancora necessario effettuare la calibrazione Z. Segui il manuale, capitolo Primi Passi, sezione Sequenza di Calibrazione. " is longer then definiton on line 1081
[E]: Text "Scaricando filamento" is longer then definiton on line 1117
[E]: Text "Usati nella stampa" is longer then definiton on line 1125
count=311
offs=638
size=9811
lang=pl
[E]: Text "\x1b[2JWykrywanie zderzen moze\x1b[1;0Hbyc wlaczone tylko w\x1b[2;0Htrybie Normalnym" is longer then definiton on line 13
[E]: Text "\x1b[2JUWAGA:\x1b[1;0HWykrywanie zderzen\x1b[2;0Hwylaczone w\x1b[3;0Htrybie Stealth" is longer then definiton on line 17
[E]: Text "Dostrajanie Z:" is longer then definiton on line 25
[E]: Text "i nacisnij pokretlo" is longer then definiton on line 41
[E]: Text "Obydwa konce osi dojechaly do gornych ogranicznikow?" is longer then definiton on line 45
[E]: Text "SpoolJoin [wl]" is longer then definiton on line 49
[E]: Text "SpoolJoin [wyl]" is longer then definiton on line 57
[E]: Text "AutoLadowanie fil." is longer then definiton on line 65
[E]: Text "Kalibracja nieudana. Sensor nie aktywowal sie. Zanieczysz. dysza? Czekam na reset." is longer then definiton on line 101
[E]: Text "Korekcja E:" is longer then definiton on line 217
[E]: Text "Wysuwanie filamentu" is longer then definiton on line 229
[E]: Text "Krancowka nie aktyw." is longer then definiton on line 233
[E]: Text "Went. ekstrudera:" is longer then definiton on line 257
[E]: Text "Informacje o ekstruderze" is longer then definiton on line 261
[E]: Text "Autolad. fil [wl]" is longer then definiton on line 273
[E]: Text "Autolad.fil.[N/D]" is longer then definiton on line 277
[E]: Text "Autolad.fil.[wyl]" is longer then definiton on line 281
[E]: Text "Predkosc went." is longer then definiton on line 289
[E]: Text "Sprawd.went. [wl]" is longer then definiton on line 297
[E]: Text "Sprawd.went.[wyl]" is longer then definiton on line 301
[E]: Text "Filament wychodzi z dyszy a kolor jest czysty?" is longer then definiton on line 321
[E]: Text "Fil. nie zaladowany" is longer then definiton on line 325
[E]: Text "Przedni went. druku?" is longer then definiton on line 369
[E]: Text "Sprawdzanie czujnikow" is longer then definiton on line 429
[E]: Text "Czy plyta stal. jest na podgrzew. stole?" is longer then definiton on line 493
[E]: Text "Znaleziono stare ustawienia. Zostana przywrocone domyslne ust. PID, Esteps, itp." is longer then definiton on line 681
[E]: Text "Kal. PID zakonczona" is longer then definiton on line 701
[E]: Text "Grzanie sondy PINDA" is longer then definiton on line 709
[E]: Text "Port RPi [wl]" is longer then definiton on line 889
[E]: Text "Port RPi [wyl]" is longer then definiton on line 893
[W]: No displ[E]: Text "Rozpoczynanie Selftestu" is longer then definiton on line 925
[E]: Text "Ustaw. temperatury:" is longer then definiton on line 953
[E]: Text "Sortuj [brak]" is longer then definiton on line 973
[E]: Text "Sortuj [czas]" is longer then definiton on line 977
[E]: Text "Sortuj [alfabet]" is longer then definiton on line 985
[E]: Text "Dzwiek [Glosny]" is longer then definiton on line 993
[E]: Text "Dzwiek[Wylaczony]" is longer then definiton on line 1001
[E]: Text "Dzwiek [1-raz]" is longer then definiton on line 1009
[E]: Text "Dzwiek [Cichy]" is longer then definiton on line 1013
[E]: Text "Kalibracja temp." is longer then definiton on line 1061
[E]: Text "Musimy przeprowadzic kalibracje Z. Kieruj sie Samouczkiem: rozdzial Pierwsze Kroki, sekcja Kalibracja." is longer then definiton on line 1081
[E]: Text "Rozladowanie fil." is longer then definiton on line 1113
[E]: Text "Rozladowuje filament" is longer then definiton on line 1117
[E]: Text "Uzyte podczas druku" is longer then definiton on line 1125
[E]: Text "Szczegoly kal. XYZ" is longer then definiton on line 1177
[E]: Text "Zalad. wszystkie" is longer then definiton on line 1217
count=311
offs=638
size=9173
lang-build.sh finished with success
config.sh started
Arduino main folder: OK
Arduino builder: OK
AVR gcc tools:
objcopy OK
objdump OK
Output folder: OK
Objects folder: OK
Generated elf file: OK
Generated hex file: OK
config.sh finished with success
postbuild.sh started
checking files:
folder OK
elf OK
objects OK
running progmem.sh...OK
running textaddr.sh...OK
checking textaddr.txt...NG! - some texts not found in lang_en.txt!
missing text ignored!
extracting binary...OK
updating binary:
primary language ids...awk: line 2: function strtonum never defined
OK
primary language signature...OK
converting to hex...OK
secondary language data...Updating languages:
Czech : OK
German : OK
Italian: OK
Spanish: OK
French : OK
Polish : OK
postbuild.sh finished with success
Respondido : 16/07/2019 3:00 pm
RE: Firmware 3.7.1 and 3.7.2 language change not possible
Solved!
Flashed 3.7.2 with Linux Slic3r without any warnings and errors. With W7 i had no luck.
Respondido : 23/07/2019 5:34 pm
