Fine Z Calibration with gauges
irunfastrr
(@irunfastrr)
I was curious if there is a way to adjust the nozzle height (like you are able to while running first layer calibration) without extruding?   I would like to use a feeler gauges to really hone in the bed but cannot find an option to do so.
If not - will taking the Z axis down to 0.0 bring the nozzle to its first layer height?  I can just work from there if need be.
Or am I just going about this the wrong way...
Note: My prints are coming out good I just want to fix the small trouble areas that sometimes cause print failures.
Posted : 19/05/2020 3:26 am
r3l471v157
(@r3l471v157)
RE: Fine Z Calibration with gauges
If you use octoprint there is a plugin that measures 9 points of the heatbed and displays the values. It called “Prusa leveling” or similar, cant check at the moment. It is intended for if you changed the spacers beneath the heatbed to nylock nuts or springs but it gives you the information either way.
Posted : 19/05/2020 10:15 am
r3l471v157
(@r3l471v157)
Oh, and you can read out the values from the calibration using g codes, but I can’t help you with that. Ask google 🙂
This post was modified 6 years ago by tmicke
Posted : 19/05/2020 10:17 am
irunfastrr
(@irunfastrr)
Perfect I was going to start looking into octoprint anyways thank you!
annnd of course just as I posted this question my motherboard went out on me so I am now working on that instead... ugh
Posted : 29/05/2020 6:49 pm
