Filament sensor turning itself off
Upgraded to latest firmware and this issue started. I didnt want to upgrade, but cant run prusalink without it. So here is the issue. I run a print and the filament runs out and it keeps printing. so i think "ok some settings may have been lost after upgrade" I check and the filament sensor is on, but the autoload and runout are set to N/A in the menu. I click them and they turn on. do another test print and it does the same. go back to menu and they are N/A again. I re enable and wait to see after 10 seconds they go N/A again. If I have them On it will detect the filament that I insert, but even with the sensor ON and those 2 options in N/A it it will not detect filament. Whhy is the setting reverting back to N/A and not holding the settings. I have checked the sensor and wiring and all is fine. Is there a setting to save my settings or something I am missing?
RE: Filament sensor turning itself off
How did you solve it?
Why is this marked as solved?
