[Resuelto] Filament sensor turning itself off
XscarfX
(@xscarfx)
Upgraded to latest firmware and this issue started.  I didnt want to upgrade, but cant run prusalink without it.  So here is the issue.  I run a print and the filament runs out and it keeps printing.  so i think "ok some settings may have been lost after upgrade"  I check and the filament sensor is on, but the autoload and runout are set to N/A in the menu.  I click them and they turn on.  do another test print and it does the same.  go back to menu and they are N/A again.  I re enable and wait to see after 10 seconds they go N/A again.  If I have them On it will detect the filament that I insert, but even with the sensor ON and those 2 options in N/A it it will not detect filament.  Whhy is the setting reverting back to N/A and not holding the settings.  I have checked the sensor and wiring and all is fine.  Is there a setting to save my settings or something I am missing?
Respondido : 30/09/2024 4:10 pm
Danster
(@danster)
Miembro
RE: Filament sensor turning itself off
How did you solve it?
Respondido : 05/11/2025 9:48 pm
nathanjshaffer
(@nathanjshaffer)
Miembro
Why is this marked as solved?
Respondido : 31/01/2026 1:19 am
