Extrusion fine for short period - then stops
Bomantz
(@bomantz)
I'm having an issue with extrusion.
When I load filament, the bond gears rotate and properly feed the filament.  I get consistent, straight, continuous extrusion.  If I answer N to the Y/N prompt immediately after it appears, I continue to see consistent extrusion.  If however, I wait for several seconds before responding N to the prompt the result is that no further extrusion takes place.  The bond tech gears do not appear to move...at least the passive one.
When I go to print anything, or do a first layer calibration, there's no extrusion at all...not even the primer strip.
I'm at a loss.  Any guidance would be appreciated.  Thanks.
Publié : 25/07/2020 6:45 pm
