Extruder skipping
Lately I experience a problem with a skipping extruder: When I am in Filament Loading mode it will extrude all day with no skipping but as soon as I start to print a model the extruder will start skipping right from the start. However I do not print that fast, I don't think the extruder would have to extrude more while printing than while loading.
The problem has arrived more or less overnight, the feed wheels are clean and I have not changed anything, the printer has printed the same PETG filament successfully so far, and the hotend temperature while printing is 10° higher than while loading.
What do you recommend to look into to solve this?
Napsal : 12/09/2025 11:42 am
