"Err: MINTEMP" After Slice Engineering Thermistor Upgrade
I just finised up installing the bondtech + mosquito extruder upgrade, and now am seeing a "Err: MINTEMP"
This seems to be tied to the Thermistor of the heatend;
I then figured that flashing the new firmware mentioned here would fix it: https://www.bondtech.se/en/knowledge-base/firmware-updates-for-prusa-i3/
But after the firmware update, I just see a thermometer Icon; which I assume it telling me the same issue is occuring.
I rechecked my cables, and ohmed it out;  Seems to match up w/ slice engineerings RT Table:
 https://docs.google.com/spreadsheets/d/1904x5JK-Sup-cX5DqHiiZWaFVTK6_PQBFxgi_6yXEJw/edit#gid=0
 https://www.sliceengineering.com/products/thermistor-high-temperature
Any thoughts?
Thanks
RE: "Err: MINTEMP" After Slice Engineering Thermistor Upgrade
FYI,
I successfully resolved this by installing 3.8 FW instead. Not sure why though.
