[Résolu] Default profile after configure new printer
livius
(@livius-2)
Hi
i have read about multiple sheets https://help.prusa3d.com/en/article/steel-sheet-profiles_1955
but i still do not know which profile i have configured at start?
When i assemble my printer i have calibrated steel sheet so where it is saved?
I now need to configure textured for PETG and save it. But i then will do not know to which profile i should switch back?
Is default "Steel sheet 1"?
Best Answer by Robin:
The quick-cycle-feature in the first level menu just cycles through the sheets that have been configured. If you added one to the first, you should only toggle between these two via the quick-cycle.
See: https://help.prusa3d.com/en/article/steel-sheet-profiles_1955
Publié : 15/02/2022 8:06 am
You start with one sheet, calibrate it, and go...
It's not until you add a second sheet (Setup menu) and name it that you are offered a choice.
Mark your sheet somewhere outside the print area (Paint/Sharpie) to keep track.
Publié : 15/02/2022 1:56 pm
livius
(@livius-2)
RE: Default profile after configure new printer
Yes i have configured second sheet - textured, but where is my first sheet saved, under which name?
Or settings are lost? And i must again configure my first sheet and it will be then saved?
Publié : 15/02/2022 2:25 pm
Click on the sheet item and it should cycle.
Publié : 16/02/2022 1:09 am
livius
(@livius-2)
Yes i can choose from 8 sheets, but which one is my first which i have configured as i have assembled printer kit?
Now when i added second saved as textured1 where is my first?
Publié : 16/02/2022 8:09 am
Robin
(@robin)
Publié : 16/02/2022 4:00 pm
livius
(@livius-2)
"The quick-cycle-feature in the first level menu just cycles through the sheets that have been configured"
this explain all, thanks, i see it is automatically saved as "Smooth1"
Publié : 16/02/2022 6:34 pm
