Corroded wire to heat bed
foogee
(@foogee)
As shown in the below picture, the power wire to my heatbed is badly corroded and fried looking. Any idea what causes this? Can I just replace the wire?
Napsal : 11/11/2019 4:18 pm
Nikolai
(@nikolai)
RE: Corroded wire to heat bed
Looks like there are some bad cables out there:
https://forum.prusa3d.com/forum/original-prusa-i3-mk2.5s-mk2.5-general-discussion-announcements-and-releases/bed-cable-failure-a-new-one/
@Admins: Please forward this information to QC department. So far it looks like some cables are bad crimped by the factory and causing this issue.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Napsal : 11/11/2019 6:01 pm
rmm200
(@rmm200)
If your cable is long enough, crimp on a new connector. You can also run a new wire - and crimp on two connectors.
Just do a better job than the factory did.
I also suspect Support would send you a new cable - but I would just make my own.
Napsal : 11/11/2019 6:10 pm
foogee
(@foogee)
thanks for the help
Napsal : 12/11/2019 3:45 pm
PPRRUUSSAA
(@pprruussaa)
electro-chemical corrosion caused by different elements connecting each other (for example stainless steel and aluminium -> a result is the white Aluminiumoxide).
The result of the chemical process is increasing resistance, heating up the contacts, melting the ports  - Carsten
Napsal : 12/11/2019 7:25 pm
foogee
(@foogee)
@umaker
At least I learn something when these errors happen! thanks for the description that makes lots of sense.
Napsal : 12/11/2019 7:44 pm
