Config wizard Z-Axis with adjusted height in firmware.
Carson Harris
(@carson-harris)
Membre
(Lots of text in here.  Sorry in advance.  TLDR: Longer Z axis, config wizard not happy)
I upgraded my Mk 3S to a Mk 4, and decided to slap the unused mk3 parts onto the frame of an old CR10 to essentially have a larger MK3.  I'm at the stage now where I'm modifying the firmware to accept the longer axes.  I've got X and Y working with the initial setup wizard, but when it gets to the Z-Axis it plunges the nozzle into the bed before stopping and telling me there's been a problem.  I've set the Z_MAX_POS value in the firmware the same as I have for x and y.  I've tried Z_MIN_POS at the original 0.15 and at 0.00.  I have also tried adjusting the pinda offset from the nozzle, but that doesn't seem to have had any effect.
I did have to move the bed up a bit.  Do I need to put in physical stops on the vertical rods, or is there possibly something I'm missing in the firmware?
Publié : 27/11/2023 7:44 pm
1 personnes ont aimé
UNPRINT3D
(@unprint3d)
Membre
RE: Config wizard Z-Axis with adjusted height in firmware.
Hi, did you find out what needs to be changed to make it work?
Publié : 04/02/2024 4:13 pm
