Check axis length - Y failing after calibration
RE: Check axis length - Y failing after calibration
the Y axis is not travelling full distance, the Prusa uses stall detection to identify the extremities of the axis, if the motor stalls too early because of friction, ubolts catching on the frame, lack of lubrication... faulty idler bearing, idler bearing mounting screw too tight, toothed motor pulley rubbing on the motor mount... lots of options... 🙂
try moving the Y axis, by hand, and see if there is any obvious sticking point.
@joantabb
Thanks for your reply - I just tried moving it - I do have to give it a pretty hard push to keep it moving after it tends to give pretty easily at first push.
@joantabb
Threw some lube on the rods - its running like a champ now. Thank you
Have you lubed the X and Z axis too!
