Can't compile firmware anymore: 'nullptr' was not declared in this scope
Tiago
(@tiago)
Trying to compile new firmware 3.5
I'm getting this compile error: 'nullptr' was not declared in this scope
I'm using all prusa steps and my gcc version shows version 4.8.1.
Also i checked plantform file and gnu11 is present since nullptr is a c++11 feature.
Then i also tried with latest arduino 1.8.7 and i get same error.
Anyone have this problem too?
Complete log:
Aviso: platform.txt do núcleo «Marlin AVR Boards» contém recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}" deprecados, convertidos automaticamente para recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Considere actualizar este núcleo.
In file included from sketch\ConfigurationStore.cpp:6:0:
ultralcd.h:160: error: 'nullptr' was not declared in this scope
uint8_t choose_menu_P(const char *header, const char *item, const char *last_item = nullptr);
ConfigurationStore.cpp:171: error: expected constructor, destructor, or type conversion before '(' token
static_assert (EXTRUDERS == 1, "ConfigurationStore M500_conf not implemented for more extruders, fix filament_size array size.");
ConfigurationStore.cpp:172: error: expected constructor, destructor, or type conversion before '(' token
static_assert (NUM_AXIS == 4, "ConfigurationStore M500_conf not implemented for more axis."
ConfigurationStore.cpp:180: error: expected constructor, destructor, or type conversion before '(' token
static_assert (sizeof(M500_conf) == 188, "sizeof(M500_conf) has changed, ensure that EEPROM_VERSION has been incremented, "
exit status 1
Publié : 23/11/2018 5:27 pm
Tiago
(@tiago)
Re: Can't compile firmware anymore: 'nullptr' was not declared in this scope
After many tries and edits i fixed the problem by using the Visual Micro with Visual Studio and set the extra flags there.
Compiled now!
Publié : 23/11/2018 6:23 pm
Blodorn
(@blodorn)
What specifically did you do to fix this? I'm having this problem right now, and would really like a solution.
Publié : 02/01/2019 6:10 am
Tiago
(@tiago)
I've added -std=c++11 at compiler flags on Visual Studio with Visual Micro
Publié : 07/01/2019 9:57 pm
