Can't compile firmware anymore: 'nullptr' was not declared in this scope
Trying to compile new firmware 3.5
I'm getting this compile error: 'nullptr' was not declared in this scope
I'm using all prusa steps and my gcc version shows version 4.8.1.
Also i checked plantform file and gnu11 is present since nullptr is a c++11 feature.
Then i also tried with latest arduino 1.8.7 and i get same error.
Anyone have this problem too?
Complete log:
Aviso: platform.txt do núcleo «Marlin AVR Boards» contém recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}" deprecados, convertidos automaticamente para recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Considere actualizar este núcleo.
In file included from sketch\ConfigurationStore.cpp:6:0:
ultralcd.h:160: error: 'nullptr' was not declared in this scope
uint8_t choose_menu_P(const char *header, const char *item, const char *last_item = nullptr);
ConfigurationStore.cpp:171: error: expected constructor, destructor, or type conversion before '(' token
static_assert (EXTRUDERS == 1, "ConfigurationStore M500_conf not implemented for more extruders, fix filament_size array size.");
ConfigurationStore.cpp:172: error: expected constructor, destructor, or type conversion before '(' token
static_assert (NUM_AXIS == 4, "ConfigurationStore M500_conf not implemented for more axis."
ConfigurationStore.cpp:180: error: expected constructor, destructor, or type conversion before '(' token
static_assert (sizeof(M500_conf) == 188, "sizeof(M500_conf) has changed, ensure that EEPROM_VERSION has been incremented, "
exit status 1
Re: Can't compile firmware anymore: 'nullptr' was not declared in this scope
After many tries and edits i fixed the problem by using the Visual Micro with Visual Studio and set the extra flags there.
Compiled now!
What specifically did you do to fix this? I'm having this problem right now, and would really like a solution.
I've added -std=c++11 at compiler flags on Visual Studio with Visual Micro
