"Calibration failed - check the axes and try again" MK3/S+, SOLVED
JulieL
(@juliel)
I didn't see this problem for MK3/S and neither the solution, so I post this here. I assembled the MK3/S/+ and used the calibration wizard. I received the following error message: "Calibration failed - check the axes and try again".
I contacted support and was told to check belt tension:
Initial belt tension: x: 241--> 237 y: 250-->259
Support: Try to loose the X axis belt slightly, the 241 is on the edge, but 237 will cause the error.
I removed the extruder plate to reach the x belt and loosened it a little bit. New belt tension: x: 237-249, y: 259-260 (didn't touch y belt, don't know why values changed).
Started the wizard again and the error message was gone.
Respondido : 16/06/2022 5:32 pm
The belt tension figure is a measure of the resistance felt by the stepper when moving the axis. On a correctly set up machine this does equate, roughly, to belt tension.
Make your next print this:
https://www.prusaprinters.org/prints/46639-tension-meter-for-the-gt2-belts-of-i3-mk3s-or-prus
It MUST be printed in Prusament PETG or the spring tension will be wrong.
Respondido : 16/06/2022 6:39 pm
JulieL
(@juliel)
RE: "Calibration failed - check the axes and try again" MK3/S+, SOLVED
Now that my printer works I can print one of those 😊 Thanks!
Respondido : 16/06/2022 11:09 pm
