Broken extruder wire
I left the room and came back to find my print had not stuck to the surface (textured surface). All of the filament had stuck to the hotend. When pulling it off, I accidently pulled loose a wire. It may be the hotend thermistor wire. How can I fix this? Here is a photo link.
Napsal : 21/12/2019 8:45 am
RE: Broken extruder wire
Put some sleeving on the wire, re solder the ends together, insulate with sleeving.
if the sleeving is heatshrink sleeving, shrink to size!
Napsal : 21/12/2019 9:55 am
