Bed very difficult to move suddenly
ThinLayersDesign
(@thinlayersdesign)
Using a MK3S.
I completed a print and started another one by my homing failed.  The bed is extremely difficult to move even without power.  No screeching noise like it has a bad bearing. I don't see any physical blockage in the carriage.  Any ideas?
Postato : 27/10/2019 10:36 pm
rmm200
(@rmm200)
RE: Bed very difficult to move suddenly
Sounds like you crushed a bearing by clamping it too tight. What axis?
Postato : 27/10/2019 11:16 pm
Seizing bearings is common when you assemble it without grease.  More often if you popped a ball out inserting the rods. As Robert said, try loosening the U-bolts until they wiggle, if the bed moves easy - great. Tighten them back up, but only until the wiggle slack is gone.
Postato : 28/10/2019 7:23 am
