Bed levelling tests not repeating
Lee_Bash
(@lee_bash)
Hi everyone,
I've recently took the plunge to do the nylock bed mod on my i3 mk3s, in order to dial in the bed and get it flatter.
I've carried out the mod and in the process of getting it flat, however I'm finding the pronterface g80/g81 results arent repeating more than twice- I.e. I can run the test three times and the third result gives slightly different results. This is the same whether I run the test at temp. or leave it cold. All tests performed within minutes of each other.
Am I missing something here?
I have tried levelling the bed, performing XYZ cal and then run g80/g81 in pronterfsce but still get similar problems.
Pulling my hair out a little!
Best regards,
Lee.
Napsal : 03/05/2020 11:13 am
