Bad Y Axis Shift. Can you help me identify the problem?!
Myers Woodshop
(@myers-woodshop)
Utenti
Bad Layer shifting in i3 mk3s. right is first print, left is second AFTER belt tightening.
Running latest firmware, 3.7.2. hatbox pla. .20 with 25% infill. using prusa slicer 2. belts feel tight and are within acceptable range according to settings numbers. after i tightened belt i reran xyz calibration, heat calibration, cleaned bed with acetone. Can't figure it out.
Y axis layer shift. Any help is very welcome at this point as my 1/4 priced ender 3 is printing better at this point...
www.youtube.com/myerswoodshop
Postato : 05/08/2019 10:00 pm
Dave Avery
(@dave-avery)
RE: Bad Y Axis Shift. Can you help me identify the problem?!
is crash detection on and did any crashes register?
Postato : 05/08/2019 10:04 pm
Myers Woodshop
(@myers-woodshop)
Utenti
crash detection is on.  not sure if any registered.  will it show me the last print stats somewhere?
Postato : 05/08/2019 10:07 pm
Dave Avery
(@dave-avery)
try with crash detection off - there is a known issue with over sensitivity to Y crashes
Postato : 05/08/2019 10:11 pm
depending on precision of printer's (ziptie) assembly, crash detection could be a problem, thats why i never used crash detection "on" since i'm printing miles of different filaments without any problems.
Postato : 06/08/2019 10:59 pm
