Bad Y Axis Shift. Can you help me identify the problem?!
Bad Layer shifting in i3 mk3s. right is first print, left is second AFTER belt tightening.
Running latest firmware, 3.7.2. hatbox pla. .20 with 25% infill. using prusa slicer 2. belts feel tight and are within acceptable range according to settings numbers. after i tightened belt i reran xyz calibration, heat calibration, cleaned bed with acetone. Can't figure it out.
Y axis layer shift. Any help is very welcome at this point as my 1/4 priced ender 3 is printing better at this point...
www.youtube.com/myerswoodshop
RE: Bad Y Axis Shift. Can you help me identify the problem?!
is crash detection on and did any crashes register?
crash detection is on. not sure if any registered. will it show me the last print stats somewhere?
try with crash detection off - there is a known issue with over sensitivity to Y crashes
depending on precision of printer's (ziptie) assembly, crash detection could be a problem, thats why i never used crash detection "on" since i'm printing miles of different filaments without any problems.
