.05 First Layer Question
x50arm
(@x50arm)
I sliced a 75x75 square and set the first layer to .05mm. When it printed the display showed .15mm for the first layer, but it was printing at .05. I got my z set so it prints a good sheet .05 thick, just wondering if anyone could explain what the display showed .15mm?
Postato : 08/04/2018 3:28 am
Kwaad2
(@kwaad2)
Re: .05 First Layer Question
I have no idea why it would do that, unless it simply won't let you "print" at less than 0.15mm...
A better question is why would you bring your first layer so low? The risk to damage the PEI sheet is so VERY high.
Hi, I'm Sean. I used to work on CNC machines.
I try to not make mistakes, but the decision is YOURS.
Please feel free to donate to my filament/maintance fund.
Postato : 08/04/2018 4:15 am
x50arm
(@x50arm)
[/quote]
[/quote]
I was trying to see how accurate my live z was. No damage to pei and verified it is printing at .05 even though the display says it is not. Damaged pei wouldn’t be the most expensive thing I’ve broken screwing around. 😛
Postato : 08/04/2018 4:20 am
Kwaad2
(@kwaad2)
[/quote]
[/quote]
Good luck replacing the PEI... it's sold out... 😛
Honestly, of everything on my printer that is NOT replaceable I consider my sheets to be the top. (that, and the frame pieces)
Postato : 08/04/2018 5:06 am
