RE: Weird layers alignment
All the screws are tightened and one is against the flat side.
The smooth rods are in good condition. Sure not as new but good
Trapezoid nut I was talking about
I don't see any prior mentioning of the trapezoid nut in your previous posts, so this picture was out of context. Again, I'd check the grub screws, which I mentioned before and Joan posted pictures of.
the POM nut on the lead screw?
(Black thingie)
Yes exactly. Is it possible that if it’s ruined it causes that layers?
Sure. Could be. Also, the screws on this one should not be as tight as other screws but a bit loose.
Oh, why shouldn’t be tight?
