Trimming A Replacement PTFE Tube
Wingsy
(@wingsy)
This link shows what I'm trying to do - prepare a replacement PTFE tube.
https://manual.prusa3d.com/Guide/How+to+trim+PTFE+tube+-+MK2-S+MK2.5+and+MK3/500
I left the following question there but I think I won't get an answer for quite a while so I'm reposting my question here:
I’m trying to make my own tube from a roll of PFTE. I can get a good concave end using a countersink, but the convex end is difficult. I tried holding that end against a rotary sander but can’t hold it steady enough and rotate it at the same time. The angle is uneven. So I tried chucking it in a drill and holding that end against sandpaper. The tube has a slight natural curvature to it (from being in a roll for so long) and I get an uneven angle again. So, I put a 5/64 drill bit inside the tube to hold it straight and tried again. Better but I can still see some unevenness. My question is, how critical is it that the convex end have a perfect angle all the way around?
Respondido : 12/10/2018 6:54 pm
Re: Trimming A Replacement PTFE Tube
have you tried sticking a 1/16 or 5/64 or 1.8mm drill up the inside of the PTFE to keep it straight?
Respondido : 12/10/2018 7:21 pm
Wingsy
(@wingsy)
Joan,
Yes. I said that in my post. But thanks anyway. Think my slightly uneven taper will be OK?
Mmmm... looks a lot worse in a magnified picture,
Respondido : 12/10/2018 11:14 pm
Area51
(@area51)
Miembro
When upgrading my MK3 to R3 I changed PTFE tubes as well.
Decided to make a jig for the job:
Link to Thingiverse PTFE Tool Jig
Besides the printed parts you will need a hobby knife with 9mm blade and a 60 degree center drill.
BTW your taper (chamfer) looks good 😀
Respondido : 12/10/2018 11:49 pm
Mustrum Ridcully
(@mustrum-ridcully-2)
Area51 very nicely done thanks for the useful tool
Respondido : 12/10/2018 11:52 pm
Wingsy
(@wingsy)
Area51, thanks for your opinion on my chamfer. I'll proceed with the replacement with what I have (I did another and made it more even). And thanks for your tool set ... I'd print them out if I could and I'd use them if I knew what to do with them. 🙂
Respondido : 13/10/2018 10:21 am
Area51
(@area51)
Miembro
Thanks 🙂
On Thingiverse I have photos showing, how to use the jig: Thingiverse link
That combined with Prusa guide to PTFE trimming should make it easy.
Respondido : 13/10/2018 2:13 pm
