Smart outlet shutdown?
Michael Pierich
(@michael-pierich)
I would like to be able to turn off my machine remotely instead of using the power switch.
Any way this can harm the machine due to lack of a shutdown sequence?
Thanks.
Postato : 03/01/2024 4:26 pm
Walter Layher
(@walter-layher)
RE: Smart outlet shutdown?
I don't think there is a big difference if you use the switch on the PSU or another switch that is further upstream. In each case it is just a simple switch. I just would wait a few minutes after the end of a print job until the hotend has been cooled down by the fan again. 5 minutes should be enough.
There are other schools of thought ... 😉
Postato : 03/01/2024 4:46 pm
1 persone hanno apprezzato
I've done it literally thousands of times. No issues. Some will argue to let the hotend cool down first. Probably good advice but I just turn them off at any time.
Postato : 03/01/2024 4:56 pm
Jimbo70
(@jimbo70)
It is best to unload the filament before you fully shut down the printer.
Postato : 03/01/2024 10:40 pm
