Slic3r Prusa Edition 1.40.1 - FINAL
Página 1 / 9
Jakub Dolezal
(@jakub-dolezal)
Miembro Admin
UPDATE: there is a new version of the Slic3r https://shop.prusa3d.com/forum/general-discussion-announcements-and-releases-f61/slic3r-prusa-edition-1-41-0-final-release--t23511.html
Slic3r PE currently reached FINAL stage and is included Original Prusa Drivers & Apps 2.1.8. This version is recommended to all users 😉
New heatbed graphics
What is new
- This version is equal to the release candidate 2 (RC2), more info below
Download link:
https://www.prusa3d.com/drivers/ (recommended)
https://github.com/prusa3d/Slic3r/releases/tag/version_1.40.1
Full changelog:
Please report any bug here:
https://github.com/prusa3d/Slic3r/issues
We wish you happy printing and look forward to your feedback!
Previous versions:
Slic3r PE currently reached RC2 state and is close to the final release. Our developers fixed several bugs and we recommend beta testers to upgrade to this version. Note that this is still a testing release for experienced users 😉
What is new
- This release brings several bugfixes
- Fixed missing tooltips on OSX
- Fixed execution of Perl post-processing scripts (Windows)
- Fixed random OctoPrint data transfer issues
- ... and many more, see the full changelog
Download link:
https://github.com/prusa3d/Slic3r/releases/tag/version_1.40.1-rc2
Full changelog:
Hi there,
our developers just released beta of Slic3r PE 1.40.1, which is full of new features! This is a testing version for experienced users 😉
What is new
- Firmware updater extended and will upload language dictionaries starting the next firmware release 3.3.0-RC1
- Real heatbed graphics is used for the Original Prusa i3 MK2S and MK3 printers
- Object remains selected even when rotating or panning with the 3D view
- NetFabb STL fixing service integrated (Windows 10), right-click on the object and select "Fix STL through NetFabb"
- OctoPrint integration improved, new dialogue with options to rename G-code, specify a target path and many others
- AMF loading improved, Slic3r PE now recognizes, whether the AMF file is compressed (.zip)
- Many bug fixes, see the full changelog
- 3D scene code was rewritten from Perl to C++
Download link:
https://github.com/prusa3d/Slic3r/releases/tag/version_1.40.1-beta
Full changelog:
Hi guys,
great news, we released Slic3r PE 1.40.0, which is full of new features! This is a stable final version and will be added to the next version of the drivers.
New welcome screen
What is new
- Integrated firmware updater for Arduino based boards (e.g. MK2S's Mini RAMBo or MK3's Einsy RAMBo).
Built in FW updater
- Completely reworked G-code preview colored by a feature type: speed, volumetric speed, filament color, etc.
To enable preview you must export the G-code first
- New super strong Gyroid infill thanks to @supermerill based on this research paper
New gyroid infill in a detail
- Full localization into eight languages Czech, English, French, German, Italian, Polish, Spanish and Ukrainian
- Automatic detection whether a model fits inside the print volume.
- 3MF format support and AMF format compression
- Enhanced multi-material support with per filament wipe amount and a variable layer height.
... and many more 😉
Download link:
https://github.com/prusa3d/Slic3r/releases/tag/version_1.40.0
Full changelog:
1.40.0-final https://github.com/prusa3d/Slic3r/releases/tag/version_1.40.0
1.40.0-beta https://github.com/prusa3d/Slic3r/releases/tag/version_1.40.0-beta
1.40.0-alpha1 https://github.com/prusa3d/Slic3r/releases/tag/version_1.40.0-alpha1
Assembly manuals
/ Knowledge Base
Respondido : 27/05/2018 9:57 pm
devilhunter
(@devilhunter)
Re: Slic3r Prusa Edition 1.40.0-beta
Been testing it for a few days, and i LOVE IT!
Love the printer selecter, love the automatic updating stock settings, love the newer-ish interface, love the detailed preview window settings after export.
Great work Slic3r dev Team!
Respondido : 27/05/2018 10:07 pm
Gato
 Gato
(@gato)
Agreed. Been using alpha and now beta version. Such a great step forward. Great job and thanks!
Respondido : 28/05/2018 12:40 am
michael.a35
(@michael-a35)
Thank you for the update.
I had a question. If the "update built-in Presets automatically" option is not selected, is it possible to check for updates manually?
edit: and THANK YOU for giving us the option to change that green text to a different color 😆
Respondido : 28/05/2018 1:12 pm
Jakub Dolezal
(@jakub-dolezal)
Miembro Admin
...If the "update built-in Presets automatically" option is not selected, is it possible to check for updates manually?...
Currently only an automatic option is available, you can select it later on in the menu "Configuration -> Preferences".
Assembly manuals
/ Knowledge Base
Respondido : 29/05/2018 9:28 am
Protoncek
(@protoncek)
I love it, too! What's great is that app is finally starting with exe only, so easy transfer of STL from fusion 360 to slic3r is possible.
However, i wonder: is it possible to hide unused (unwanted) filaments? There are soooo many of them and i'm kinda lost in all those data and thus hard to find the one i need. Previously i deleted all profiles except one i use...
Or at least it would be great if custom filament profiles would be at the top, not at the bottom.
Respondido : 29/05/2018 7:37 pm
thomas.m45
(@thomas-m45)
With 1.40.0-beta, I'm not able to connect to OctoPrint.
When I configured the settings IP and API an test, it returns:
Slic3r has encountered an error
Could not connect to Octoprint: HTTP 400: HTTP response code said error (22)
Note: OctoPrint version at least 1.1.0 is required.
My Version of Octoprint is 1.3.8.
In the last version of Slic3r, it worked without any issue.
Thanks for the great software ...
Thomas
Respondido : 30/05/2018 10:59 am
Jakub Dolezal
(@jakub-dolezal)
Miembro Admin
Hi Thomas,
just tested the connection between Slic3r 1.40.0-beta and PrusaPrint (OctoPrint) 1.3.8 and it works as it should.
Jakub
Assembly manuals
/ Knowledge Base
Respondido : 30/05/2018 11:19 am
thomas.m45
(@thomas-m45)
Hi Jakub,
thanks for the info. Unfortunately mine did not.
For your info, when I started 1.40 first time, it took over all the settings from the previous version. Exeception was Octoprint, where the fields have been empty.
Any further idea?
I'm using Slic3r on a Mac Book. Can you probably tell me how to make a full rest of all the settings?
Thomas
Respondido : 30/05/2018 11:58 am
Jakub Dolezal
(@jakub-dolezal)
Miembro Admin
Hi Thomas,
to replace old profiles with new ones, please open the Slic3r PE and from the top row select "Configuration" -> "Configuration Assistant" and then tick the option "Remove user profiles". Let me know if it helped 😉
Assembly manuals
/ Knowledge Base
Respondido : 30/05/2018 5:10 pm
Tiago
(@tiago)
My preview view looks different and locked:
How to unlock and add that new view features?
Respondido : 30/05/2018 10:58 pm
Kohinoor2
(@kohinoor2)
Export G-code and the new coloring by feature type will appear. I don't know what you mean by locked preview view - sorry.
Respondido : 31/05/2018 1:15 am
thomas.m45
(@thomas-m45)
Hi Thomas,
Hi jakub,
this did not work too. No I'm really confused. It worked all the time without any issues. Just the last update to 1.40 "caused" the problem.
Meanwhile I rebooted my mac, I rebooted my Octoprint Server and I tried it again with previous versions of Slic3r. Unfortunately nothing changed.
Thomas
Respondido : 31/05/2018 10:57 am
hasuhepaki.h
(@hasuhepaki-h)
gsgdgdgfd
Respondido : 31/05/2018 4:19 pm
TheLightSpeed!
(@thelightspeed)
Hey, So I don't use Slic3r that much... the inability to customize supports drives me to S3D always. But when I do try to use Slic3r PE I have a weird glitch. On my MacBook if I have the dock visible Slic3r will not go over the top of it. Basically as I open windows they all go over the dock like they should, but Slic3r sits behind it. So I have to manually go into my settings and hide the dock, or minimize Slic3r. It is so annoying.
Respondido : 31/05/2018 4:44 pm
Tiago
(@tiago)
Yes that worked out, thank you
Respondido : 31/05/2018 10:27 pm
JMcK
 JMcK
(@jmck)
Any chance of getting the print time estimated before exporting gcode. I like adding the time estimate to the file name, similar to the gcode files preloaded on the SD that ships with the printer. And it’s a PITA in the current version since you have pop out to the OS’s GUI/command line to rename the file after export.
It would be super awesome if I could just add {EstimatedTime} to the filename template...
When someone asks you if you're a god, you say, "YES!"
Respondido : 01/06/2018 2:05 pm
LordGarth6
(@lordgarth6)
i second this, just having the "output filename format" have a [print_time] variable would be perfect
Respondido : 01/06/2018 6:28 pm
MrMik
(@mrmik)
I am having problems using the "Flash printer firmware" function.
Slic3r provides this error message:
avrdude: Version 6.3-20160220-prusa3d, compiled on May 23 2018 at 19:06:12
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/tmp/.mount_Slic3rUtVMMi/usr/bin/resources/avrdude/avrdude.conf"
Using Port : /dev/ttyACM0
Using Programmer : wiring
Overriding Baud Rate : 115200
avrdude: ser_open(): can't open device "/dev/ttyACM0": Permission denied
avrdude done. Thank you.
Respondido : 03/06/2018 5:29 am
MrMik
(@mrmik)
Is there a way to turn on the 'Slice now' button when objects do not fit on the print bed?
I find it most annoying that it does no longer let me compare 2 versions of an object side by side. I find that to be an invaluable tool to improve the print-ability of my designs.
I suppose I can use version 1.39 for that, but I'd rather do everything in the one Slic3r.
Respondido : 03/06/2018 5:32 am
Página 1 / 9
