Reinstalled extruder, but now getting under-extrusion: causes?
Mat
 Mat
(@mat-3)
Hello!
About 2 hours into a print, filament stopped coming out. Sounds like a block, right?
After cancelling the print, I heated up the extruder to PLA temp, and went into settings > move axis > extruder. The filament reversed back out okay, but when I increased the value it seemed to stop up against something.
Clogged hotend?
I gently pushed the filament whilst increasing the value, and then filament started to extrude again.
Does that mean it's unclogged now, and I can carry on? Or should I address the initial cause?
Also I noticed that the layers were not very well stuck together. I was printing a project box, and the sides had started printing but they just lifted off the base.
Sounds like classic under-extrusion right?
What is the cause of these two things?
Here's the background:
This was my first print after reinstalling my hotend to the extruder, after replacing the heater and thermistor blocks.
I also took the opportunity to replace the PTFE tube with a new one (sourced from Prusa shop so it should have the correct angles and cuts etc)
Calibrated ok and things seemed fine. I ran a long print and set up an electric heater nearby my enclosure as the enclosure is near a window and it can get drafty (temps of around 2 degrees in the nighttime here).
There seem to be quite a few variables so I'm not sure where to focus to prevent these two problems happening again?
Este debate ha sido modificado el hace 4 years por Mat
Respondido : 18/01/2022 12:15 am
First stop the drafts, a heater is no fix, a screen or curtain is better.
Respondido : 18/01/2022 12:36 am
Mat
 Mat
(@mat-3)
RE: Reinstalled extruder, but now getting under-extrusion: causes?
Thanks - forgot to mention that my printer is in an enclosure. The heater was just there to prevent drafts getting in through the gaps...
Respondido : 18/01/2022 2:05 pm
Bad first layer adhesion is either a poor first layer Z calibration or a dirty print-sheet.
Respondido : 18/01/2022 3:03 pm
Mat
 Mat
(@mat-3)
I am not getting bad first layer adhesion! The adhesion problems I had were after about 20 layers between a 3mm bottom piece and side walls
Esta publicación ha sido modificada el hace 4 years por Mat
Respondido : 18/01/2022 3:06 pm
OK, photo's?  That sounds like warping, another symptom of drafts...
Respondido : 18/01/2022 7:22 pm
