Prusament PC Blend / Glue
Dustin
(@dustin)
When using the glue, what is the recommended method for cleaning the print bed between prints?
Opublikowany : 15/01/2021 3:25 am
jsw
 jsw
(@jsw)
RE: Prusament PC Blend / Glue
If you mean the glue stick, I usually clean it off with IPA, and when I do use glue stick I usually take it completely off after a print.
When I use Layerneer I kind of buff it off with IPA between prints and when it gets too well used I'll take it off completely.
Opublikowany : 15/01/2021 9:11 am
Posted by: @dustin-7
I use magigoo or dimafix from time to time. The adhesion agent is relatively easy to remove with warm water after printing.
Opublikowany : 15/01/2021 11:35 am
Glue stick is specifically designed to be washed off with water.  Water actually works better than IPA for some reason.
Opublikowany : 15/01/2021 11:37 am
Dustin
(@dustin)
@jsw what’s IPA?
Opublikowany : 15/01/2021 12:47 pm
@dustin-7
isopropyl alcohol, the stuff Prusa recommends for cleaning their print sheets.
Opublikowany : 15/01/2021 12:54 pm
@dustin-7
Isopropanol 99.9%: https://hoefer-shop.at/technische-chemikalien/isopropanol/1-liter
Opublikowany : 15/01/2021 1:25 pm
Dustin
(@dustin)
Got it...I figured that’s what it was.
Opublikowany : 15/01/2021 1:38 pm
Dustin
(@dustin)
I presume it’s best to clean after each print?  Sorry for the barrage of questions, I just haven’t found much info online regarding Prusa’s procedure for this.
Opublikowany : 15/01/2021 2:12 pm
@dustin-7
I do not.  I will use a wet sponge to slightly smooth if it is roughened up.  I will add more if there are blad spots.  Once every week to two weeks, I wash the plate and reapply.
Opublikowany : 15/01/2021 2:18 pm
Christopher
(@christopher-8)
Magigoo PC.   Works very well
Opublikowany : 15/01/2021 2:21 pm
Tailsld
(@tailsld)
Wash off with water , dry and clean with isopropyl alcohol
Opublikowany : 15/01/2021 3:41 pm
I am finalizing a review on Magigoo: http://3dprinterreviewblog.com/2021/01/15/review-magigoo/
Opublikowany : 15/01/2021 5:59 pm
1 ludzie polubili
jsw
 jsw
(@jsw)
Glue stick tends to build up, something that Layerneer and similar products do not.  If/when I use glue stick I will usually clean it off after each print.  I've found that denatured alcohol seems to cut the glue stick residue a bit better than IPA.
Opublikowany : 15/01/2021 6:03 pm
Dustin
(@dustin)
Does layerneer work with PC Blend?  On their website it says untested.
Opublikowany : 15/01/2021 6:19 pm
jsw
 jsw
(@jsw)
I don't do that many PC Blend prints, but I have tested Layerneer with some small-footprint PC Blend parts and it appeared to work fine.  After the cool-down a quick flex of the smooth sheet and they popped right off.  (Of course I tried this on the one partially-damaged sheet I have, so NBD if it had resulted in further damage.)
I would be confident using it for PC Blend jobs that do not have large flat surfaces against the build plate.  For those, I would probably use glue stick, as recommended by Prusa.
Opublikowany : 15/01/2021 6:24 pm
@jsw
It works on smaller prints.  I would say it is hit or miss on larger ones.
Opublikowany : 15/01/2021 6:39 pm
jsw
 jsw
(@jsw)
Posted by: @cwbullet
@jsw
What's the approximate footprint dimensions of the largest PC Blend print that you've done?  I was thinking, and the largest I think I've ever done was the replacement fan shroud for the printer.
Opublikowany : 18/01/2021 10:21 am
I printed several that were 100 mm x 100mm or more.  They tended to warp a little.  Even a little can lead to issues.  I have one printer that I replaced all the parts with Urban Grey PC Blend. I just rebuilt it in PETG.
Opublikowany : 18/01/2021 1:10 pm
