Printer can no longer print 1 st layer
jlefevre1
(@jlefevre1)
I have a 3 month old Mark 3  that I assembled from a kit. It started up fine and over the next 3 months printed over 500 parts and amassed about 800 hours of prints without problems. Now suddenly I cannot get it to print anything. I am trying to print parts that I have printed dozens of before, using the same file on the same SD card. Printer had not moved and is on a sturdy bench mounted on a concrete floor in a climate controlled workshop. The problem is that the feed of the filament skips and blobs and curls up and stick to the nozzle intermittently. It will however print the first layer calibration flawlessly. I have done the following; 1.. replaced and cleaned the nozzles ( 3 of them all the same 0.4 PRUSA units.  2... Tried 5 different filaments, 2 from PRUSA one from Amazon and 2 from Push Plastics..  3... replaced the knurled gears that move the filament..  4...  Run the set up wizard from start to finish 10 times with no failures  5..  Cleaned and cleaned the steel sheet, tried both sides with hot water and dish washing detergent and acetone and tried printing with and without the KORES glue.  6.. completely dissembled and checked and the entire hot end assembly 2 times..  7...  Cleaned and reclined the nozzles using cold pulls and loading and unloading filament and using the needle.
I have a entire new hot end assembly ordered that should arrive next week. After I try that I am out of ideas.
I can run a perfect first layer calibration and then go straight to a print and the first layer will fail. The outline it draws around the part usually works but then everything falls apart. the first layer edges all curl up at the edges, I get voids where nothing prints at all, the PLA sticks to the nozzle, there are skips in the lines. If I do manage to get all parts of of the first layer to be there it will still have curled edges here and there which the nozzle or PINDA will ram into and tear off the heat bed on the next layer. When I stop the print and go to remove the damage first layer some parts of it a not stuck very well and other parts are stuck so well I have to scrape them off with my finger nails.
If I move the Z axis up and and use the load routine and observe the filament coming out of the nozzle it is in blobs and various thickness and shoots out sideways sometime and sticks to the nozzle surface. Am I wrong or should it come out uniform and straight down without blobs or curling and sticking to the nozzle edges. I am using filaments that are both new and also the end of a roll that came with the machine and had produced hundreds good parts.
Any ideas welcome.
Any ideas welcome.
Respondido : 16/01/2021 6:48 pm
RE: Printer can no longer print 1 st layer
This reads like an insufficiently cleaned print bed:
Clean the bed again. Use dishwashing soap and HOT water; rinse well and dry with fresh paper towels.
Avoid touching the surface afterwards.
The curling at the nozzle might just be stickiness due the residues from previous failures, unless extreme this shuldn't be a problem; BUT, have you been printing abrasive filaments (metal fill, luminous &c.) in which case you might have some wear?
Hth, Cheerio,
Respondido : 16/01/2021 7:50 pm
Miembro
Clean bed with dish soap and water.  Dry thoroughly.
If it fails, consider looking at whether you live Z is low enough.
Respondido : 16/01/2021 8:39 pm
jlefevre1
(@jlefevre1)
@diem
I am printing with PLA only. Solid colors, no abrasives. Note I stated that I am using filaments that worked before from the same spool that will not work now.
I have washed the crap out of the base plate with Dawn and hot water and dried with both paper towels and clean cloth towel. I only touch the edges. This is the same procedure I have used for 3 months in the same sink with the same water and same towels.
I have replaced the nozzle 3 times with brand new.
Please read my original post as I have covered all of this in it.
Respondido : 17/01/2021 12:20 am
jlefevre1
(@jlefevre1)
I have tried every calibration of the Z axis possible. Again as stated in my original post the Z axis calibration runs perfectly all the way from to far to to close to just right. None of them will make a suable print but the all work perfectly running the first layer calibration.
Again please read my original post more closely as this was covered in that document.
Respondido : 17/01/2021 12:24 am
Miembro
Post an image of your Z Calibration on the forum.  I am more than glad to assist,
Respondido : 17/01/2021 2:04 am
Peter M
(@peter-m)
Wen my first layer does not work I do this:
The problem with myself is, that the first layer is not good, but I think it is good. To low is bad for higher up in the print.
I usually do the first layer calibration to high, a few steps higher, then print a few squares , every square I do a little lower, then I take the one that looks the best, one layer that is very low but still looks good could be bad, model could come loose higher up in the print, if you go even lower the first layer could get waves in the filament.
Respondido : 17/01/2021 1:55 pm
Miembro
@peter-m-3
Then use a rim or brim to increase adhesion.
Respondido : 17/01/2021 2:26 pm
@jlefevre1
If you are doing all you say then you are getting perfect prints every time...
This still reads like an imperfectly cleaned steel sheet.
So does this.
As it's only three months old you shouldn't have had any need for acetone yet.
The next, relatively easy step is to pull and reseat all electrical/electronic connections in case something has worked loose or corroded.  Also a quick clean of the bondtech gears - just a whisk with a clean paintbrush and a visual check that they remain in alignment.
Hth, Cheerio,
Respondido : 17/01/2021 4:38 pm
jlefevre1
(@jlefevre1)
I think I may have found the culprit. After cleaning the print sheet for the umteenth time in a number of days that I lost track of, alwasy using hot water and Dawn dishwashing liquid and a very soft bristle brush to scrub of the KORES stick, I headed back to the shop. As I was holding the sheet by the edges as usual the light caught it just right and I notices blotchy areas of white haze on the surface. The light bulb went on and I remembered what a mess our city water is. I have to replace the water pressure regulator and clean the faucet and shower heads at least every 2 months and flush the water heater with vinegar every 6 months to keep everything working due to the extreem levels of disolbed limestone and calcium deosits in our water. I remembered some where that it was recommend to clean the print sheet with alchol or acetone. I grabbed a can of acetone and wetted a paper towel and that quickly removed the white haze from the sheet. Then without putting any of the KORES on it for adhesion I started a part and the first layer was perfect. It finished and I did a quick wipe with the acetone and started another and the first layer was perfect. They stuck to print sheet well and I had only to flex it a couple fo times to get them off. I do thing I have a bad roll of black PLA from another vendor but I am afraid to try it again since it alwasy made things worse and seemed to plug up the head. I have ordered the correct color from PRUSA and will try that when it get here.
Keeping my fingers crossed. Thanks all for pointing me in the bed condition as being the culprit. I just did not see that as a posibility sind the first layer calibration alwasy ran perfectly. Maybe since it runs much slower and is a simpler pattern that problem was not showing up with it and the little square it prints at the end is in a part of the print sheet that I never use.
Respondido : 17/01/2021 4:47 pm
@jlefevre1
From your last paragraph it sounds as if you're using the built-in live Z method ("little square at the end"), which I found to be pretty useless. Instead I suggest you try this: https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/life-adjust-z-my-way/
I changed it a bit by using a different sized square but it gives you a much better visual indication of what's going on with the live Z, plus -- to your specific issue -- covers a much wider range of the print bed.
Respondido : 18/01/2021 12:02 pm
Miembro
A little spray of Aquanet sticks better than Kore Glue Stick.
Respondido : 18/01/2021 12:32 pm
