New fan shroud?
Anasz
(@anasz)
New fan shroud?
Is this a new version of the fan shroud? I print the fan shroud from time to time using sunlu ABS+ and decided to try prusament PC blend. Is this an updated fan shroud for mk3s or should I just get R4 fan shroud?
Veröffentlicht : 20/12/2020 10:57 am
Area51
(@area51)
Mitglied
RE: New fan shroud?
Yes - This is the new fan shroud for the MK3S+ upgrade.
I think it is necessary to upgrade the extruder printed parts before it will fit the changed design.
Veröffentlicht : 20/12/2020 4:57 pm
Mitglied
RE: New fan shroud?
@area51
I just printed it this weekend.  I really like the extra arm.  I think it will add stability.
Veröffentlicht : 21/12/2020 10:44 am
Area51
(@area51)
Mitglied
RE: New fan shroud?
@cwbullet
The old design was a little flimsy, only hold in place with one screw and the fan casing. The new design is better.
Veröffentlicht : 21/12/2020 12:29 pm
Mitglied
RE: New fan shroud?
@area51
Concur.  I installed it and it seems mroe stable.  I am sure the same will be true after heating.
Veröffentlicht : 21/12/2020 1:04 pm
Area51
(@area51)
Mitglied
RE: New fan shroud?
@cwbullet
Is it a direct replacement on the MK3S or do I have to upgrade other parts on the extruder to MK3S+ to use the new fan shroud?
Veröffentlicht : 21/12/2020 1:15 pm
jsw
 jsw
(@jsw)
RE: New fan shroud?
The one in the screenshot above looks similar in shape to the one I printed a while back but without the reinforced parts.  The remixed one that I used is on the left below and the stock one is on the right.  I printed them both in PC Blend and made the decision which to use when I had the machine torn apart for replacement.  The remixed one came from the Prints section here and is a drop-in replacement.  I'm sure a search would find it.
My stock fan shroud started to droop a bit after a fairly long run of ABS prints, so I decided to replace it, and it gave me a good excuse to try out the PC Blend.
Veröffentlicht : 21/12/2020 1:55 pm
Mitglied
RE: New fan shroud?
@area51
It was for me.
Veröffentlicht : 22/12/2020 1:23 am
Anasz
(@anasz)
RE: New fan shroud?
Silly me did not realize the removable support. Only realized after examining it closely, I thought it was weird that the only wind channel was the little triangle hole. After trying it out I think it is more stable. It is uncomfortably close to the heat block though. But since I printed with PC , time will tell.
Veröffentlicht : 22/12/2020 7:21 am
neworder
(@neworder)
RE: New fan shroud?
@anasz
Silly me too! Thank you to mention it here! For a removable support it was quite hefty printed in PC 😀 😀 😀 😀  .
Veröffentlicht : 23/12/2020 5:43 pm
Bladevane
(@bladevane)
RE: New fan shroud?
So are we saying the horizontal bar that comes very close to the nozzle should be removed before fitting? Thanks.
Veröffentlicht : 25/02/2021 3:21 pm
Next Layer 3d
(@next-layer-3d)
RE: New fan shroud?
@anasz
Thanks for mentioning that the bar with the triangular cutout is a support structure.  I've been trying to print a new shroud out of ASA and have been struggling with that piece.  I couldn't understand why it was there.  I just snapped it off of my most recent print and it broke away nice and clean.
Veröffentlicht : 11/03/2021 1:27 am
foxkid
(@foxkid)
RE: New fan shroud?
Just bought a printed replacement fan shroud of PC.  It was a new design that didn't fit my extruder due to the new support beam.
Question:  If I replace all the extruder plastics with fresh design, fresh printed PC, will I have all the other parts needed?  I have an original i3m3, with the extruder upgraded as part of the MMU2S upgrade.  I think this means that I have the MK3S part set, and not the MK3S+ parts set.
-- Carl
Veröffentlicht : 15/03/2021 11:40 pm
Next Layer 3d
(@next-layer-3d)
RE: New fan shroud?
@foxkid
Yes, I upgraded my extruder from the MK3S to the MK3S+ and it had the new fan shroud design.  I recently purchased the MK3S+ printer and liked the new extruder design, especially the extra support for the pinda probe.  Files for the upgrade are here: https://www.prusa3d.com/prusa-i3-printable-parts/   - in the upgrades section.
Veröffentlicht : 16/03/2021 12:05 am
Anasz
(@anasz)
RE: New fan shroud?
@foxkid
You are supposed to break off the support
Veröffentlicht : 16/03/2021 12:18 am
Mitglied
RE: New fan shroud?
@anasz
Either that or it will warp away.
Veröffentlicht : 16/03/2021 9:59 am
