MK3 M3 Nut sizes or print tolorence issue
Geakster
(@geakster)
I have a working MK3 i built my self from sourced parts. It prints really good how ever when I print the parts to make another MK3 my M3 nuts do not fit in to the printed parts. I started off with a home built reprap and printed MK3 parts, when i printed with the reprap I had the same issue, so I heated the nuts up to push them in place in the printed parts so that I could get the printer going. I thought that maybe my reprap wasnt as accurate but the MK3 i built has the same issue, in some of the smaller holes the M3 nuts simply wont fit, they are too thick.
now am i missing a setting? the MK3 calibrates its self and its pretty darn accurate. So is it the M3 nuts im using? do they make a slimmer M3 nut? Just to be clear im NOT talking about the square nuts although them didnt fit either.
Please remember I built these myself and I tried to order every thing to spec. I used to have a bunch of the prusa i2 long ago and loved them now im trying to go with the MK3. Thanks in advance.
Postato : 05/12/2019 2:36 am
Geakster
(@geakster)
RE: MK3 M3 Nut sizes or print tolorence issue
No one knows this answer? :*(
Prusa really must have special M3 nuts they hide from the world lol...
Postato : 06/12/2019 12:15 am
Mick
 Mick
(@mick-4)
Is it the outside size of the nut or its thickness?
Nuts are manufactured for different uses, the standard being a "full nut". You can also get a "half nut" which is thinner. This can also be called a lock nut, thin nut or jam nut. They are typically used with a full nut to stop it from moving.
I hope this is of some use.
Regards
Mick
Postato : 06/12/2019 7:17 am
1 persone hanno apprezzato
Chocki
(@chocki)
Could it just be the shrinkage of the material?.
I found that if you try to print a 4mm hole and a 4mm peg there is no way they will fit together (Using PETG T-Glass printed at 260 Deg C).
Even if the calibration was off the same error would be applied to both the peg and hole so in an ideal world, they would fit albeit with a tight fit, in reality I have to print the hole at 4.3mm with the peg at 4mm to get a fit that does not require unreasonable force.
The same recently for a drill guide for a 4mm drill, the holes had to be printed at 4.3mm else they were much too small. I did look at adjusting the steps /mm value to get finer resolution for adjusting my prints, but on the 8 bit board there simply isn't the processing capability to deal with a finer step value required as it would be too much for the EINSY to process during fast movements, so you should do some test prints for sizes and adjust your designs to get the correct real world values where accuracy matters.
In slicer there is an setting which you can adjust to compensate for shrinkage which I believe is used for holes, but I have not actually played with this yet, maybe someone whom has could shed some light on how it works, or do what I have been doing and measure prints, and adjust my drawing to allow for the difference between real and design measurements.
You may want to buy one of these: 150mm / 6 inch Dial Plastic Vernier Caliper Measurement Gauge
They are good enough for most 3d printing and invaluable to get prints made to fit properly, and start from only a few £'s if in the UK (Amazon), and require no batteries so can be left for long times without that usual, the batteries are dead again feeling.
Postato : 06/12/2019 7:45 am
Geakster
(@geakster)
@michael-f27
it is the thickness is the issue, sorry I should have clarified that. I tried looking for thinner nuts but dosnt seem to be some thing i can find for the M3 size.
Postato : 06/12/2019 9:18 am
Geakster
(@geakster)
I am currently trying to print it at 02.mm as it is suggested spec instead of 0.1mm to see if that might be the issue?
Postato : 06/12/2019 9:32 am
Geakster
(@geakster)
@chocki
I dont think its shrinking but it is always a possibility. I've tried a couple different materials
Postato : 06/12/2019 9:33 am
Hi Cevans,
there are at least two thicknesses of square nuts,
Prusa use the thin one!
is this the issue?
Thin Nuts  (1,8mm Thick)
https://www.ebay.co.uk/itm/M2-5-M3-M4-M5-M6-M8-M10-THIN-Square-Nuts-A2-Stainless-Steel-Type-DIN-562/292079244600?var=591053828452&hash=item4401479538:m:m2DzBq-PQSihZnQVhOYKgGg
Thick nuts (2.4mm thick)
https://www.ebay.co.uk/itm/M3-M4-M5-M6-M8-M10-Sqaure-Nuts-Square-Machine-Screw-Nut-Stainless-Steel/202766171808?var=502907620070&hash=item2f35ce3ea0:m:mWPvkHJ2jZhB3q42cbkWZlQ
Joan
Postato : 06/12/2019 9:49 am
Geakster
(@geakster)
@joantabb
its not the square nuts, its the hex nuts that are too thick.
Postato : 06/12/2019 10:10 am
@cevans9921
How thick are your Hex nuts?
https://www.ebay.co.uk/itm/M3-M4-M5-M6-M8-STAINLESS-STEEL-A2-HEXAGON-HALF-LOCK-THIN-NUTS-FOR-BOLTS-SCREWS/121544225928?hash=item1c4c99b488:m:muD8kUkxf4_hbkrFgvXntjA
this site gives you a picture of assorted M3 fasteners
https://www.westfieldfasteners.co.uk/A2_Nut_M3.html
Postato : 06/12/2019 10:47 am
Geakster
(@geakster)
@joantabb
when i use the micrometer it shows my hex nuts are 2.32mm thick
Postato : 06/12/2019 10:53 am
M3 thin Locknuts are 1.8mm thick
Postato : 06/12/2019 11:29 am
Geakster
(@geakster)
ahhh that is the issue then, I appreciate it 😀
Postato : 06/12/2019 3:22 pm
@cevans9921
Good luck. Joan
Postato : 07/12/2019 5:44 pm
