"Little" problem
janos_herc
(@janos_herc)
"Little" problem
I downloaded the finished pen project of thingiverse.com.
Filament was PLA.
Put a print and waited for the first 3 layers to make. Went to sleep and in the morning I see this. Nightmare.
I'm not sure how he didn't react with some sensor to stop?
What to do? is there any help?
Publié : 12/03/2020 10:51 pm
Lichtjaeger
(@lichtjaeger)
RE: "Little" problem
https://help.prusa3d.com/en/article/extruder-blob_2005
Publié : 12/03/2020 10:56 pm
rmm200
(@rmm200)
There is no spaghetti sensor. Octoprint does have a plugin though.
Great danger lies ahead. If you are not careful you will break wires - or worse.
Acquire a heat gun. Heat that mass up so you can start to - gently - remove that blob a piece at a time.
I can't really recommend a soldering iron.
Patience is a virtue here.
Not that it makes you feel better - but this would not have happened with a clean build plate and a correctly set Z.
Come back when you have it sorted and we will try to help.
Publié : 12/03/2020 11:01 pm
janos_herc
(@janos_herc)
I solved the problem!
Before each print, I thoroughly clean the board with alcohol. I've been printing for days and I really don't understand how it happened. Never mind, in the future I'll take better care.
Thanks for the info!
Publié : 13/03/2020 8:36 am
rmm200
(@rmm200)
Congratulations!
But you don't get away that easy...
Alcohol is only a partial answer. Use the highest percent you can get. 91% is OK - 99% is better.
Contaminated alcohol is worse than no alcohol. It just spreads grease around. Preferably keep your alcohol in a spray bottle.
Never touch the top of an IPA bottle with a rag - you will contaminate it.
And IPA is not a substitute for a regular scrub with lots of hot water and an unscented detergent like Dawn. Dry with a clean paper towel and never touch the print surface. Do this maybe monthly.
Would still like to see a calibration square so we can see how your Z is doing.
Publié : 13/03/2020 4:16 pm
1 personnes ont aimé
janos_herc
(@janos_herc)
@robert-rmm200
Can you tell me whitch calibration square? Pls link or something?
Publié : 13/03/2020 7:24 pm
there is a zipfile at the bottom of the first post, which contains test squares for PLA, PETG and ABS...   (Nothe the heatup process is two stage, 160C first ( I think), then full temp...
Publié : 13/03/2020 9:13 pm
janos_herc
(@janos_herc)
Z    is   -0.700
Publié : 13/03/2020 9:38 pm
rmm200
(@rmm200)
Well - your Z looks super to me. Thanks for posting.
(especially the one you printed on the ceiling. Talk about good adhesion!)
Publié : 13/03/2020 10:35 pm
janos_herc
(@janos_herc)
@robert-rmm200
maybe the room temperature problem? it is 13-14 degrees (Celsius) in that garage.
currently doing parts for printer enclosure.
Publié : 13/03/2020 11:33 pm
