X axis detection impossible
caroline.b2
(@caroline-b2)
I finished to assemble my new MK3 but I have a big problem.
The installation wizard is blocked during the "X axis detection" and after few minutes it starts moving the x axis very slowly to the left. I try moving the three axis (X/Y/Z) in the menu of the printer and they all do the same...
Here is the video :
https://wetransfer.com/downloads/9633a279bc5fabd3997582637dfd42eb20181106120846/72f096f7c81f97aeff2f5d8981871d2420181106120846/aa46a5
https://www.dailymotion.com/video/x6wvnqv
As you can see:
- The X axis move easily by hand
- At 28 secondes we can hear that the front fan is doing a strange noise (I untight the screw and it's the same)
- At 1 minute and 6 secondes, it start doing the X axis test but nothing happen
- At 2 minutes and 30 secondes, the X axis start moving very slowly
- At the end of the vidéo, the X axis end is not detected...
Thanks for your help
Publié : 08/11/2018 11:27 am
RH_Dreambox
(@rh_dreambox)
Re: X axis detection impossible
I think the screw to your X-end pulley is too tight and the pulley can not run freely.
Then loosen the two screws to extruder-idler. They should not stick out as your screws do. They should end about 1 mm inside from surface.
If the exruder-idler is to tight it will cause extrusion problems with overheated and klicking extruder motor.
Publié : 08/11/2018 5:15 pm
caroline.b2
(@caroline-b2)
Thanks for your answer but my pulley is totally free, in fact my problem is that all the 3 axis do the same, it's very strange ... It's like the Rambo MotherBoard do not send the signal to the motor as it should ...
I try to move all the 3 axis with the menu and they all move like in the video ...
Publié : 08/11/2018 8:46 pm
stephen.h14
(@stephen-h14)
Did you know that when you spin a stepper motor quickly, like you did when you slid the X axis back and forth, it makes voltage? It can be quite high and cause damage to the drivers. I see you moved it quickly enough that the LCD screen lit up. I would be concerned that you damaged the board possibly?
Publié : 09/11/2018 2:44 am
caroline.b2
(@caroline-b2)
I found how to solve my problem. I flash the firmware and everything works fine. I think that the original firmware was corrupted.
Publié : 09/11/2018 8:11 am
