What would cause these horizontal lines?
I have a factory built i3 MK3S+ with an MMU2S. The y-axis belt (the one that moves the bed forward/backward - I think it’s the Y axis, not the X axis, but I’m not 100% sure) came loose after about 2 hours of printing, and I put it back way too loose for a while before realizing my mistake and tightened it. My prints got immediately better after I tightened the belt, but now I’m getting these lines on the front face of all my prints. Is this a problem with my Y axis again? If so - what do I do? I would really appreciate any help you can give me. Thanks!
Veröffentlicht : 07/11/2021 6:59 am
RE: What would cause these horizontal lines?
Yes, forward/backward is the Y-axis direction. Did you check if pulley on Y-motor maybe became a bit loose?
[Mini+] [MK3S+BEAR]
Veröffentlicht : 07/11/2021 7:38 am
