Please attach .3mf
Please zip and attach your .3mf file to a post.
Mk3S+,SL1S
Respondido : 17/10/2021 2:46 pm
As Sylivia says with the 3mf more can be determined but that looks like the seam.
Its pretty much unavoidable on models shaped like that. Normally the slicer is set to try and hide the seam in a corner but that geometry has no corners. You can adjust where its placed in the slicer software, sometimes placing it to the rear so its all in a line makes post processing to remove it easier (sanding etc). By carefully tuning your filament settings you can sometimes minimise the appearance but with filament printing you can never get rid of it fully.
Now you know what it is you can search, there are MANY threads here and elsewhere that asked the same question you have.
Respondido : 17/10/2021 8:54 pm
