Tree Frog Benchmark first print concerns (freshly completed MK3S kit, no calibration issues)
Hello,
I finished the Prusa MK3S kit, calibrated successfully, and printed the benchmark 50-micron frog as a test.
It came out mostly fine but I noticed some slight stringing and a bit of extra flakes and bits on the surface. Granted, I will wet sand the PLA (galaxy silver) but is there anything I should do to improve the print quality?
Please see the attached photos. The nozzle also made a string that continues all the way to the print. All factory default settings and using frog gcode included on the SD card. Z spacing was about 0.8mm and first layer looks fine. Perhaps an issue with retraction? Extruder issue? Maybe everything is totally fine and there is always a bit of post-processing to do?
Respondido : 09/05/2020 3:57 am
