Small holes in first layer where lines meet
3dstuff
(@3dstuff)
Hi all,
I'm having a problem on the first layer. See images.
What I did:
Flow on the MK3 is raised from 95 to 100.
File is sliced with slic3r. First layer extrusion width is raised from 0.42 to 0.45 (could this be the problem?). Overlap is default 25%. Part is printed in PETG.
Anybody an idea what I could try next?
Posted : 04/08/2018 9:53 am
toaf
 toaf
(@toaf)
Re: Small holes in first layer where lines meet
im guessing its getting messed up from the circles right? can you print one flat one layer with no problems? I swear when it circles something it spits filament at a higher rate.
Posted : 04/08/2018 10:31 am
3dstuff
(@3dstuff)
When I print a simple square first layer, that is without circles in it, it does a good job. Sometimes I get small holes around one of the edges but not as much as with the circles in it.
Posted : 04/08/2018 10:37 am
toaf
 toaf
(@toaf)
maybe shell thickness?
Posted : 04/08/2018 11:29 am
RufusClupea
(@rufusclupea)
I get the same thing around curves; circles, lettering, etc. wherever perimeters adjoin top/bottom layer infill.
I assumed it was just a glitch/quirk of the technology.
Could (hang on...) Infill/perimeters overlap (Advanced Print Settings) have anything to do with it?
That's "MISTER Old Fart" to you!
Posted : 04/08/2018 4:30 pm
[...] Could (hang on...) Infill/perimeters overlap (Advanced Print Settings) have anything to do with it?
Yes, very possibly. I have Print Settings->Advanced->Overlap->Infill/perimeters overlap set to 25%.
Posted : 04/08/2018 9:55 pm
RufusClupea
(@rufusclupea)
That's where mine is, so it must be a default setting. I may try bumping it to 30-33% next time.
Posted : 05/08/2018 1:21 pm
[...] That's where mine is, so it must be a default setting. I may try bumping it to 30-33% next time.
I just went through my print setting presets, and I do have it adjusted depending on layer height. At 0.32mm I have it up to 50%.
Posted : 05/08/2018 7:19 pm
3dstuff
(@3dstuff)
Thx for the replies!
Gonna try that to, after I fixed my printer, while replacing the printed parts with the new versions I broke a cable of the heater cartridge.....stupiddddd!
Posted : 06/08/2018 12:30 pm
