Slight Z Wobble?
trainspotta
(@trainspotta)
Slight Z Wobble?
hey guys!
got my mk3s three days ago and assembled it in 2 sittings. No problems.
first test prints where no problem with the silver Prusament.
now using Amazon basic or 3Djake eco pla I got some kind of Z Wobble.
any ideas? Or am I to critical?
Napsal : 07/11/2020 4:03 pm
RE: Slight Z Wobble?
Why do you think its z wobble ?  To me that looks like the variance you get when the filament is not a consistent size.
Napsal : 07/11/2020 4:22 pm
trainspotta
(@trainspotta)
So maybe the filament is just shitty?
Napsal : 07/11/2020 5:11 pm
You can get that sort of variation from many things. Belts a bit loose, sticky bearings, ambient air temps moving around, cheap filament, bad model, and even slicer anomalies or non-optimal slice settings for a particular filament.
Get some time on the printer and watch for things that are a consistent problem. Print a few of the sample gcodes, too. They are good references for seeing set up issues.
As a data point, I've been using pretty much all default settings for years, and get reasonable results. There are places I do things different, but those are pretty rare. My philosophy is to not change a setting unless I can predict what it will change on the print. But I am also guilty of playing with settings just to see what they do.
Napsal : 08/11/2020 9:22 am
