Replacement of hotend
Hello, I have bought a new hotend of prusa MK3S but i received it without plug of extruder heat as in the photo.
How can i insert the pins of the new hotend in the plug of the old extruder heat ,thanks.
Opublikowany : 15/01/2021 9:28 am
RE: Replacement of hotend
Those Pins, are actually Bootlace Ferrules, intended to make a better quality connection, than bare twisted wires.
I would unplug the Heatbed existing connector from the einsy and
loosen the two screws with a flat blade screw driver, remove the old cables and insert the new cables, then tighten with the flat blade screw driver
p.s. the heatbed reference relates to the Mk2 heatbed on the older printer (Rambo mini controller)
Opublikowany : 15/01/2021 8:20 pm
