Repeatable (bad) print quality issues
Neil Ramsay
(@neil-ramsay)
I'm printing with the Prusa-supplied filament (silver PLA) that came in the box, using the files on the supplied SD card.
I printed the Prusa logo 3 times (at slightly different Z adjustments). Always, the P looks okay. The U looks kind of okay. And the other letters look AWFUL.
I then tried printing the frog (150um height version), and one side of the frog looks... okay. One side looks ghastly. What can I look at to try and debug this. One would expect, if it's underextruding, that it would be uniformly bad vs one side looking okay. But I don't know. Could the temperature be too low? Or the heat dissipating too quickly to keep the filament malleable?
Postato : 01/08/2018 8:34 pm
Rosparovac
(@rosparovac)
Re: Repeatable (bad) print quality issues
Do you have tighten you X / Y belt corectly?
It looks like looseness in printers had.
But first, dou check printer folowed by this video tutirial?
University: MK2S upgraded to MK3 with MMU2.0
Home: MK3
Materials: ABS; ASA; PETG; PET; PLA; Nylon; Nylon Carbon; CPE;
SW: Freecad 0.18; Slicer PE And still generating more troubles than whole forum together.
Postato : 01/08/2018 10:21 pm
Neil Ramsay
(@neil-ramsay)
Tension SEEMS okay. No slippage I can find. Everything calibrates properly. Went through the video tutorial post construction.
Postato : 01/08/2018 10:31 pm
Rosparovac
(@rosparovac)
This one: [youtube] [/youtube]
Home: MK3
Postato : 01/08/2018 10:44 pm
Neil Ramsay
(@neil-ramsay)
Yes. I've watched that video and done the adjustments required.
I'm not sure, if filament was not feeding properly, that the errors would be in the same place all the time. It seems like random errors would cause random issues with the prints vs a repeatably bad quality.
Postato : 01/08/2018 11:28 pm
Neil Ramsay
(@neil-ramsay)
All right. I've fixed the weirdness, it seems. It's not perfect, but everything else is just tweaking.
The culprit? What else. A set screw. The set screw on the X axis motor was slipping because of a poorly shaped cup. I replaced it with another hardened set screw I had, tightened it up, and it solved all sorts of weird print issues.
Postato : 02/08/2018 10:06 pm
excellent news.
try reducing the flow a little and the top of the prusa logo should improve
Postato : 02/08/2018 10:26 pm
Neil Ramsay
(@neil-ramsay)
excellent news.
Thanks, Joan!
Postato : 02/08/2018 11:16 pm
