Problems with LCD
wilheldp
(@wilheldp)
Problems with LCD
I suspect my problem isn't with the LCD, but that is how it is manifesting.  I just assembled my MK3s+ kit and I'm running the calibrations.  I successfully tested the fans and completed the XYZ calibration.  I was moving on to the extrusion/hot end testing, and that's when my problems began.  The startup screen and "sorting files" bar always show up fine when I start the printer or reset it.  Sometimes I make it all the way through to the extruder pre-heating, sometimes the printer fails right after the files are sorted.  But the LCD fills with a symbol that looks like an inverted H (the background is white, and the H is blue, if that makes sense).  Then the LCD switches to show a garbled mess.
When I searched the forums, I found the suggestion that it may be an improper seated LCD cable.  I have re-seated the cables and re-routed them through the Einsy enclosure several times, to mixed results.  But I really don't think it has to do with the LCD cables since the startup and file sorting screens always show up fine.
Any thoughts?  TIA.
Respondido : 04/03/2021 2:26 pm
Clarmrrsn
(@clarmrrsn)
RE: Problems with LCD
How about the SD Card, does it do the same with the card removed? Or with a different card, I seem to recall an issue with some cards?
I would suggest a reseat of all cables and check everythingis plugged in and connected correctly, if this doesn't work,sounds like possibly a firmware issue, but would suggest contacting support first via the chat on the EStore for their input.
Esta publicación ha sido modificada el hace 5 years 3 veces por Clarmrrsn
Tank you very much!
Respondido : 04/03/2021 10:09 pm
wilheldp
(@wilheldp)
@clarmrrsn
Thanks for the advice, but I think I figured it out through tinkering.  I saw some other threads talking about possibly over-tightening of the LCD into the housing.  I loosened the screws a bit.  I also pulled the ribbon cables out of the aluminum extrusions, and one of them seemed to be a bit pinched.  I was able to complete the calibrations, and I'm currently finishing up a benchy.  Everything seems to be in order.
Respondido : 05/03/2021 3:37 pm
Clarmrrsn
(@clarmrrsn)
Good news
Any other problems come back and sure someone will be able to assist.
Tank you very much!
Respondido : 05/03/2021 5:56 pm
